machinegunsquid
Kind of sounds like a flex-plate....but it wouldnt go away with being warmed up...
Could be a bad rod bearing...but that'd require pulling the motor.
Could always drain the oil, and check for metal shavings, that'd pretty much let you know the extent of the damage....
