Thread: Plugs
Results 1 to 20 of 20
  1. #1 Plugs
    GT Level Member wlmrt6's Avatar
    Sterling
    Ok so im getting really frustrated. I have an 05 gtp with a 3.6 pulley setup and am currently running al104's but i really dont want ot have to change them every few months. I want something that will last longer. Is there an ngk iridium that will perform just the same at the same heat range? or something? idk help plz.
  2. #2 Re: Plugs
    Pennsylvania
    Autolite XP104 Iridium spark plugs.
    "They take less ignition voltage to fire and have a 25% larger flame kernal than the stock plug. The also have a platinum button on the side wire to prevent gap erosion. They have a 100k life span as well."
  3. #3 Re: Plugs
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Id stick with copper. I can swap plugs in 10 min. ,and there cheap.
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  4. #4 Re: Plugs
    Pennsylvania
    Quote Originally Posted by 01gpgt01 View Post
    Yeah, he doesn't feel like that. He said so.
  5. #5 Re: Plugs
    Hagerstown,Md
    Quote Originally Posted by SlowNA06 View Post
    Whats cheaper. An engine or spark plugs? you could run NGK tr6's errr or 7's I cant remeber which is the same as 104's
  6. #6 Re: Plugs
    just because he said it doesnt mean its right. anyone not running copper plugs on their modded car is doing it wrong.
  7. #7 Re: Plugs
    Charles City, IA
    Iridiums will work too.
    SMGPFC Two Nipple General
  8. #8 Re: Plugs
    Hagerstown,Md
    FWIW, I saw between 1-2 degrees more KR on NGK's Vs the copper, and had more idle misfires
  9. #9 Re: Plugs
    Portland Oregon
    AC Delco "Platinum"
    Stock..........41-921
    1 colder.......41-932
    1-1/2 colder..41-919
    2 colder.......41-913
    The 41-913's would be the same heat range as the AL104's
  10. #10 Re: Plugs
    Sterling
    So the Al xp104 would be best?
  11. #11 Re: Plugs
    Florida
    How much driving are you doing??
    I put about 12,000miles on my Copper 104's with a single problem. Went to swap em out, still looked good. Worn, but good.
  12. #12 Re: Plugs
    Sterling
    I do alot of driving it is my daily driver. i baught the car june 27th of 2009 with 68,000 miles and today it has 98,000 miles. I also like to race it on occasion in the summer and fall.
  13. #13 Re: Plugs
    Florida
    Well, I put on about 20k a year...and only swap the 104's out twice a year.
    I'd much rather spend $12 on plugs, and spend 10minutes swapping them, than running hotter plugs.
    Plus...c'mon they are 12 bucks...and pretty damn easy to do too.
    As long as you can measure KR, feel free to run a different plug.
    The 104's and 103's are proven, great plugs.
  14. #14 Re: Plugs
    Pennsylvania
    The stock heat range AC Delco Iridium is 41-101. Does anyone know the numbers of the colder plugs?
    Iridium Plugs 2 ranges colder than stock:
    NGK TR7IX Iridium
  15. #15 Re: Plugs
    Hagerstown,Md
    AL104's are you best option or the NGK tr7's which will last longer. just change them when they need changed, I mean it takes 10min. There was just 3 poped piston threads in here in the last 3 months from people running Platinum plugs or to hot a plug..........
  16. #16 Re: Plugs
    Portland Oregon
    I don't know that there's iridium plugs in a colder heat range but if you scroll up I posted AC Delco platinum plugs that are colder heat range.
  17. #17 Re: Plugs
    Pennsylvania
    Yeah, I read gud. Can't think of a single soul that cares about platinum plugs, though. As far as I've read, folks either want copper or iridium.
  18. #18 Re: Plugs
    Portland Oregon
    Iridium has a smaller tip which gets hotter and promotes pre-detonation People hate bosch platinums, but AC delco platinums were actually a factory plug for the grand prix's before the iridium were used
  19. #19 Re: Plugs
    Sterling
    A friend of mine runs double platinum ngk's in his race car.
  20. #20 Re: Plugs
    ....so? no one tried to claim your 'friend' was smart. copper plugs are always the way to go in a performance application.
  1. NGK TR6 plugs
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-05-2010, 01:36 PM
  2. plugs
    By PONTIACGTP05 in forum Introductions/Noob Questions
    Last Post: 04-08-2010, 07:37 PM
  3. plugs?
    By banzai7 in forum General Tech Discussion
    Last Post: 07-12-2009, 06:05 PM
  4. What plugs should i use?
    By paratroopermatt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-21-2008, 02:00 PM
  5. plugs?
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-29-2008, 12:32 PM
