Thread: 97 GTP Idleing issues or fuel pump? Help if you can.
Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
  1. #21 Re: 97 GTP Idleing issues or fuel pump? Help if you can.
    Grand Rapids, MI
    yah. idk maybe try cleaning your maf with some maf cleaner? just check everything from fuel to spark to air.
  2. #22 Re: 97 GTP Idleing issues or fuel pump? Help if you can.
    GT Level Member Whitehispanic's Avatar
    Westborough
    Check everything because it can be a very simple issue because when this stuff was happening to me I went out and bought a MAF replaced it and still didn't fix the problem the. After that I follow the vacuum line from the TB and saw it was just disconnected, so I return the brand new MAF put on the one I had on of course after cleaning it and it ran fine. These cars are tricky sometimes the littlest things make these things go bananas. Keep us updated to what happens
    *sig too tall*
  3. #23 Re: 97 GTP Idleing issues or fuel pump? Help if you can.
    Grand Rapids, MI
    these cars are DEFINITELY tricky. just look around and dont give up man. let us know if we can help
  4. #24 Re: 97 GTP Idleing issues or fuel pump? Help if you can.
    Lifer h0wl0ngcanitbe's Avatar
    Marysville WA
    Ya thanks guys I am taking it one step at a time and trying to be systematic. I just did a oil change it was scheduled so figured it could help.
    But something else is definantly acting up. I ran out of gas again for the second tank in a row. My fuel consumption has increased and my range is dropping pretty steadily. My fuel gauge is broken so im left gauging it from the trip and DIC as best as I can but for some reason my trips are decreasing. Any thought on what this could be?
    Im defiantly swapping out the pugs figured that would be worth it anyways, totally forgot to look at the vac lines while I did my oil change didnt dawn on me. Ill do that too, but yeah know what ya mean about tricky. My 01 has little issues here and their and its hard to pin point what they are. Thanks again for the help ill keep ya posted if the problem continues or if I get it resolved.
    2001 4dr Black GTP Stock and staying that was... maybe
    1997 2dr Black GTP Open Cone, GXP Rims, Black Headlights, ZZP Headers, ZZP Cat Back, Bunch of suspension parts from ZZP, ZZP 10.5MM plug wires, Autolite 605s, Overkill Tune
  5. #25 Re: 97 GTP Idleing issues or fuel pump? Help if you can.
    Marysville WA
    Ok so I finally have resolution to this problem!
    It was the MAF I switched out new plugs and the problem persisted and so then the next logical step was to just shell out the money for a new MAF. She runs great and shes already gettin better MPGs
    Thanks everyone for all your help really appreciate it!
  1. Fuel issue...possible fuel pump????HELP
    By TAWinner23 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2013, 11:50 PM
  2. Fuel pump or Fuel Pump Resistor
    By Dragan in forum General Tech Discussion
    Last Post: 01-28-2011, 08:01 AM
  3. Fuel pump / Fuel sender question !
    By 2001redfireGT in forum General Tech Discussion
    Last Post: 03-01-2010, 11:03 AM
