Thread: Valve Cover Gasket Leaks & Possible Intake Leaks
Results 1 to 5 of 5
  1. #1 Re: Valve Cover Gasket Leaks & Possible Intake Leaks
    Donating Users
    South Deerfield, MA
    Are you sure the pools are oil? Usually fluid pooling there is coolant. Every car I have seen it on, it was dirty and could be mistaken for oil if looking quickly. Failed intake manifold gaskets will leak coolant into the area you describe. I have never seen a failed valve cover gasket leak oil so bad to cause pools on the higher side of the valve cover.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  2. #2 Re: Valve Cover Gasket Leaks & Possible Intake Leaks
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    Thanks for the advice & suggestions. I will update as needed.
  3. #3 Re: Valve Cover Gasket Leaks & Possible Intake Leaks
    The valve covers should not be warped under the bolts. This is because the bolts have sleeves on them and can not be tightened to break the cover. This is where the grommet comes in. The bolt pushes on the grommet and the grommet applies pressure to the valve cover gasket. The VC's do have a bit of an odd shape to them and can look funny.
    On the LIM puddles. GM sealed the threads of the bolts holding the LIM on, because they protrude into coolant and oil passages. It is common for those sealed bolts to begin seeping fluid up onto the manifold. This is probably the info they noted on the inspection. Try cleaning the motor well and see if the seepage returns. If so, I'd recommend having someone do the LIM's and as part of the process they should reseal the bolts by cleaning them and adding a sealer with ptfe in it.
  1. Signs to look for (Gasket leaks)
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2010, 12:29 AM
  2. valve cover gasket? intake gaskets?
    By bross in forum General Tech Discussion
    Last Post: 12-17-2009, 01:16 AM
  3. Sun roof gasket leaks
    By GrandpaAl in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-26-2009, 11:05 PM
  4. Valve cover gasket
    By TorqueAutoMotiv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-14-2009, 10:25 PM
  5. valve cover gasket
    By BFish in forum 3.4L V6 (LQ1) DOHC
    Last Post: 12-12-2008, 03:51 PM
