Thread: misfire codes on GTP
Results 1 to 11 of 11
  1. #1 misfire codes on GTP
    Donating Users Vegas_Matt's Avatar
    Jul 2010
    Las Vegas, NV
    hey all
    couple days ago i noticed my EGR was sticking, which was fine the car just needed more gas than usual to get going. well that problem got worse and one day leaving my parents house to head home, my car has trouble reaching higher RPM. and from the next stop the SES light starts to flash and the car shakes horribly. after getting home i find the code is a misfire on cylinder 1.
    after this i remove the EGR and block both ports off. and still saw no change, i have pulled the fuel rails and moved the injector to another cylinder, and then got a p0300 code after startup with that.
    do i need to put the EGR back in for this car to function properly?
    is the multiple misfire code just a result of me not clearing the cylinder 1 misfire when i started the car after pulling the fuel rail.
    should i torch the gp and collect the insurance money?
    <MiZzBeCcA>its not rape if you yell suprise
  2. #2 Re: misfire codes on GTP
    whats the cat situation like?
  3. #3 Re: misfire codes on GTP
    Jul 2010
    Las Vegas, NV
    cat? what cat? nah never put one on with the headerz
  4. #4 Re: misfire codes on GTP
    SE Level Member Powertrike's Avatar
    Jul 2010
    MN, US
    Try swapping coils, see if the misfires follows said coilpack.
  5. #5 Re: misfire codes on GTP
    Jul 2010
    Las Vegas, NV
    tried swapping the wire to a different cylinder and the mis didn't move. my guess is on the injector cuz when i moved it my misfire moved. so i'm going to clean out the rails when i get new injectors here if this works. and if not i'll take OBO for the car lmao
  6. #6 Re: misfire codes on GTP
    Jul 2008
    sumter,south carolina
    cleaned teh injector yet?
    02 GTP with mods 05 GP for DD
  7. #7 Re: misfire codes on GTP
    Jul 2010
    Las Vegas, NV
    tried cleaning the injector and got nothing so far. ordered a set of injectors from a member on here. and if that's not the issue then i'll prolly scrap the car, sell off everything i can.
  8. #8 Re: misfire codes on GTP
    Jul 2008
    i hear ya on scrappin it.. i feel that way once a month or better. but these cars are cheap and easy to fix.
  9. #9 Re: misfire codes on GTP
    Jul 2010
    Las Vegas, NV
    solved the misfire problem, it was a mixture of the LIM gasket and the fuel filter. so i left my parents garage tonight and notice the lights were getting dim, 2 miles into driving i'm showing 9 volts on my scan gauge. 9 volts turns into 7, turns into stalling. car was so gutless after that i couldn't get it into a parking lot after 2 jumps.
    i guess i gotta replace the battery and the alternator but shouldn't the battery have held up through some of this abuse through the drive? i'm not showing a dead short but can there be one? and on the wiring harness where can i ground to chasis? i picked under the coil pack against the heads.
  10. #10 Re: misfire codes on GTP
    SE Level Member Vlad0691's Avatar
    Dacula, GA
    Check your grounds. The same thing happened to me and when I looked I had a cracked negative terminal on the battery. Made my car do all kinds of weird things. Just a suggestion!
    CAI, 180* T-Stat, SD Headers, EGR Delete
    I have hazy headlights <3.
    R.I.P.
  11. #11 Re: misfire codes on GTP
    Jul 2010
    Las Vegas, NV
    Problem Solved!
    The power issue was a bad alternator due to zzp's voltage booster's poorly put together connector shorting to ground... i'm starting to dislike anything ZZP has released.
    although, i guess my MAP sensor has takin a crap to the point where the DIC shows 3 bars of boost at idle -_- FML
  1. Maybe a misfire?
    By Brammer in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-27-2010, 04:24 PM
  2. Misfire?
    By Sabzz in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-17-2010, 10:52 PM
  3. Another idle surge/misfire problem with multiple codes
    By Justinzoso in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-04-2010, 11:43 AM
  4. Cylinder #1 misfire and random cylinder misfire
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 07:16 AM
  5. #5 Misfire
    By jjbskisail in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-06-2009, 02:36 PM
