Thread: Boost doesn't seem right
Results 1 to 12 of 12
  1. #1 Boost doesn't seem right
    SE Level Member speedy2's Avatar
    NW Florida
    I've been having the P0243 code. I never noticed a problem with the car until a week or so ago. Car seems sluggish. Also, the boost gauge only goes halfway when at WOT. I do notice it pegs out for a split second and then back down to halfway. I can also hear this action in the whine. I also don't leave anywhere near the amount of rubber I did before from a dead stop. lol
  2. #2 Re: Boost doesn't seem right
    Vacuum leak?
    Have you taken a look at your vac lines to see if any are broken/rubber T's torn.
  3. #3 Re: Boost doesn't seem right
    NW Florida
    The rubber on the booster cap looks good. But, the hoses on it seem cracked. But I'm not seeing a leak. Should I start there and replace all those hoses since they are cracking.
  4. #4 Re: Boost doesn't seem right
    what about the plastic vacuum lines under and around the supercharger?
    do any of thise T's and line look bad.
  5. #5 Re: Boost doesn't seem right
    NW Florida
    I looked at those too and all seem perfect. Car is a an '05 Comp G with a little over 62,000 miles.
  6. #6 Re: Boost doesn't seem right
    Bastard Reptile's Avatar
    Kansas City, MO
    I would, just for peace of mind.
  7. #7 Re: Boost doesn't seem right
    NW Florida
    is there a "kit" that has all the hoses together.
  8. #8 Re: Boost doesn't seem right
    Kansas City, MO
    GM Does offer that as a complete replacement for around $20.
    Also, an alternative, but not as nice looking is making your own from vacuum hose and plastic fittings.
  9. #9 Re: Boost doesn't seem right
    The gm prices went up, just after the first of the year i think.
    I got the full line replacment for 35ish bucks, 2 weeks ago. That didnt include the brake boost lines.
  10. #10 Re: Boost doesn't seem right
    Kansas City, MO
    It sounds like you got hosed then, because retail price is only $26.
    Actually, the ones for the 04+ are cheaper, about $15 for them. If you wanna get one from the dealer, the number for the one that runs under the SC is 12580696.
  11. #11 Re: Boost doesn't seem right
    NW Florida
    Hmm ok. you guys know the part number to that kit? Also, I could probably just get a hose anywhere for the brake booster right?
  12. #12 Re: Boost doesn't seem right
    GTX Level Member cliffdawg's Avatar
    Midvale, Utah, United States
    checkers or now that its called oreilly has vacuum line like 35 cents a foot worked great on mine so far just when i did mine i took the car there so i can get all the right lines and lengths
    SMGPFC #77
    94 Firehawk - #108 of 500
    97 GTP Coupe - Rebuilt Trans, F1 Hood, Front Air Dam, and Gen 5 Blower Swap than done with modding
  1. boost gauge doesn't light up
    By tjgenest in forum Audio, Security & Visual Electronics
    Last Post: 01-19-2022, 12:55 PM
  2. Why is my boost gauge only reading vacuum and no boost?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2010, 02:26 PM
  3. A/C Works, then Doesn't...?
    By Burls117 in forum General Tech Discussion
    Last Post: 07-03-2010, 06:35 PM
  4. dic boost gauge only shows half boost
    By SilvaMan61 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2010, 07:40 PM
