Thread: main caps
Results 1 to 12 of 12
  1. #1 main caps
    Banned
    Jun 2011
    what is the best way to remove the main caps..?.they're pretty tight fit
  2. #2 Re: main caps
    Did you remove the side bolts?
    They are side bolt mains.
    If you did that...vice grips and a rubber mallet...have at it.
  3. #3 Re: main caps
    Banned
    Jun 2011
    yeah, took the side bolts out..lol
  4. #4 Re: main caps
    Charles City, IA
    Also make sure to mark them so they go back in the same place.
    SMGPFC Two Nipple General
  5. #5 Re: main caps
    Banned
    Jun 2011
    they are all numbered and have arrows pointing toward the front made in.
    as does just about every motor i have tore apart... why would you need to mark them?
    i am beginning to wonder about some people.....
  6. #6 Re: main caps
    when you remove main caps you always want to put them back where they came from, that's just the rules of engine building 101.
  7. #7 Re: main caps
    I think he just meant be sure to keep them in order and don't move them around or put them in facing backwards.
    It has been done...
  8. #8 Re: main caps
    Odessa, MO
    What OP meant was... They are already marked and don't need marked again.
  9. #9 Re: main caps
    ive seen caps not marked a lot, but they do come marked from the factory. i was under the impression he wanted to know why they were marked. my bad.
  10. #10 Re: main caps
    Banned
    Jun 2011
    Quote Originally Posted by Abrasive View Post
    Thats it.
  11. #11 Re: main caps
    SE Level Member kygtp's Avatar
    Oct 2008
    Cincy
    Don't know if you got the caps off or not, but I ended up making a slide hammer to pull them off.
    I used a flat peice if steel with holes drilled the same width of the cap holes. I threaded the center to put a long rod on it to make the "Slide" part with a 2" dia round stock with a hole in the middle. At the top of the rod I put a couple of nuts and washers for the "Hammer" part to hit on.
    I used concrete anchors that are kinda shaped like a bell at the bottom of them and have a "sleeve" that goes over the body. Slide the stud part into the cap hole, slip the sleeve in the holes, put your plate on and secure with some washer and nuts. Once you get it tight, start hammering upward, and the caps come straight up and you don't have to worry about damaging the caps.
    If you want I will try and get a pic for ya.
    I hope this helps.
  12. #12 Re: main caps
    Banned
    Jun 2011
    Quote Originally Posted by kygtp View Post
    I hope this helps.
    i got the caps off.. good idea though, maybe try that next time
  1. Main bearing caps
    By btamayo in forum General Tech Discussion
    Last Post: 09-19-2010, 03:01 PM
  2. main cap and rod bolts
    By chev1988rolet in forum General Tech Discussion
    Last Post: 07-30-2010, 09:39 AM
  3. main cap and rod bolts
    By chev1988rolet in forum Off Topic Discussion
    Last Post: 07-30-2010, 01:46 AM
  4. Bad main bearing?
    By Teancum in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-08-2010, 11:05 AM
  5. Help! Main caps
    By speedemongtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-22-2009, 02:09 PM
