Thread: Help! Main caps
Results 1 to 10 of 10
  1. #1 Help! Main caps
    Ohio
    I need some tips. I ve got the bolts out of the main caps (including the side bolts) but i can only get #4 cap to come up. Anyone have any tips on how to get the other caps to come up. theres nothing to pry on and wiggling side to side isnt getting it either. they just rock an dont come up at all. any tips would be of a great help.
    00 GTP demodded and forsale
  2. #2 Re: Help! Main caps
    Bastard Reptile's Avatar
    Kansas City, MO
    Assuming that you have the engine on a stand and turned over. Get a rubber mallet, and tap up on the end of the crank from the top of the engine (bottom from where you're standing) and this should jolt the caps loose. Then you should be able to get a small pry bar in between the block and the caps, and GENTLY pull them out.
  3. #3 Re: Help! Main caps
    Yup...and FWIW...I used a small rubber mallet on mine and attached a big pair of vice grips to each one and as I tapped it with the mallet I wiggled back and forth on the vice. Works pretty well.
  4. #4 Re: Help! Main caps
    Ohio
    Thanks for the help! i actually ended up getting them before i got back to the comp. Used 2 prybars with rounded ends in the holes and wiggled while holding the prybars towards eachother an pulling upward at the same time. they slowly but surely came up
  5. #5 Re: Help! Main caps
    May 2008
    McHenry IL
    good deal ha
  6. #6 Re: Help! Main caps
    Banned - Busted For Scamming
    Feb 2009
    Tight fit, huh? Gm is amazing, crossbolted mains
  7. #7 Re: Help! Main caps
    Ohio
    ^ yes very tight fit!
  8. #8 Re: Help! Main caps
    Kansas City, MO
    Yes, they are tight fight. Probably for a reason.
  9. #9 Re: Help! Main caps
    SE Level Member bigdawg15005's Avatar
    pittsburgh,pa
    I like a tight fit myself...................LoL....
  10. #10 Re: Help! Main caps
    Ohio
    ^ ha i knew a comment like that was comming eventually
  1. Main engine bearing failure
    By 03grandprixgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-14-2011, 08:50 PM
  2. ongoing Issue with Ignition Main 1
    By palmergg in forum General Tech Discussion
    Last Post: 08-12-2009, 12:12 PM
  3. 3800 SII main cap removal
    By turbocharged406sbc in forum General Tech Discussion
    Last Post: 01-03-2009, 04:27 AM
  4. oil caps
    By QwikGT in forum Off Topic Discussion
    Last Post: 09-09-2008, 08:03 PM
  5. Main reason for Amp to cut Out
    By jacobmh27 in forum Audio, Security & Visual Electronics
    Last Post: 07-18-2008, 09:57 AM
