Thread: Boost help part 2
Results 1 to 6 of 6
  1. #1 Boost help part 2
    SE Level Member ElAlacran2010's Avatar
    Dec 2010
    El Paso, Texas
    so i checked all my vacuum lines.did find a leak and fixed it. replaced map, and bbv. but still i boost at wot all but one square. it flutters sometimes from all but one square to full boost. and sometimes two squares less at wot. one thing i noticed is that i dont feel any vacuum from the boost bypass solenoid to the actual bbv. the only thing i know i need to replace for sure is the supercharger coupler. my question is could the worn coupler cause a slight change in boost. or is it the boost bypass solenoid. or a combination of both. if anyone could help i would really appreciate it. LOW BOOST SUCKS ASS!
  2. #2 Re: Boost help part 2
    SE Level Member TheYanz's Avatar
    Northwest Suburbs, IL
    Hey dude. Did u take the BBV out of the car & carefully push the metal thing in & hold ur finger tightly over BOTH ports of the BBV? Even on 1 of the few BBVs I have it passed this test yet still had some sort of internal tear/ vacuum leak inside the actual thing which led to high LTFTs (indicative of a vacuum leak) with only that specfic BBV. I was def having low Boost issues at the time as well. On the BBVs there's this orange like thin rubberized membrane crap that can tear & cause issues. I would also advise AGAINST getting a replacement one from ZZP. I bought one from them & it's all retarded with the top port located in a fashion where I have to use a longer vacuum tube for the top port. I'm not saying it's ur BBV but as soon as I saw u mention that & vacuum issues relating to that I figured I'd make a comment.
    What pulley? 3.4 I assume? Yeah it should fill up.
    Worn coupler may cause such an issue. IIRC it should def affect when the boost kicks in/ boost/ throttle response feel type stuff more but not sure if it'd affect actual Boost PSI since the shaft & blades will still spin. U'll def get NOISE & boost response feel issues.
    Not sure if ur supposed to feel vacuum where u described at idle. Maybe at WOT there's vacuum there & the BBS deals with Boost dump type stuff. U mean u checked it with the car running, right?
    Also look over everything for normal maintenence like belts, make sure all the other pulleys spin freely, check the SC tensioner pulley, & make absolutely sure ur vacuum lines are rigged up poorly. Use zip ties everywhere. U can get 200 for sh*t like $5-$10.
    99' Black GTP/ '03 Motor. 3.4 MPS, 1.9 Rockers, Ported SC & TB, SD Headers, FastKatt Tune, 2.5" Exhaust, Dual Tips, 104's .055/ 180*, STBBs, 6000K HIDs + 6000K HID Fogs, Interior LEDs + Red LED Switches, 1,250w Infinity Sub, Red Calipers, NiCop Brake Lines.
  3. #3 Re: Boost help part 2
    Another thing I forgot to mention... Flow mods. I was reading up on one of the posts. Everyone was listing their max Boost PSI. I was curious 'cause I thought I had an issue with a 3.4". However I have MASSIVE flow mods w/ the SD Headers, rockers, full 2.5" exhaust, big res, big tips, etc, etc. I only make an efficient 7-8 lbs of Boost. Some people with less flow will see higher numbers. Higher Boost doesn't always mean better results. Ppl will tell u Boost = restriction in some cases. Hope some of this helps.
  4. #4 Re: Boost help part 2
    St. Louis
    I would hope that after a year the OP has figured this issue out
  5. #5 Re: Boost help part 2
    Whoops thought it was from 2012, Lol. Yeah I hope so too
  6. #6 Re: Boost help part 2
    Would you please link us to Boost help part 1. Thanks
  1. Why is my boost gauge only reading vacuum and no boost?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2010, 02:26 PM
  2. dic boost gauge only shows half boost
    By SilvaMan61 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2010, 07:40 PM
