Thread: Pulley
Page 2 of 2 FirstFirst 12
Results 21 to 32 of 32
  1. #21 Re: Pulley
    KSteelwheelzJ klj5022's Avatar
    New Carrollton,MD
    Tons...considering that nut is running the same levels of timing I am...
    Erik you quack
    Sorry what are good/Bad affect of timing. And will a 3 inch downpipe with cat delete the U Bend?
    I just wish the police loved my car as much as i do 3.5,160 Stat,HAI,ZZP F/R STB, SSAC Headers, Reptile PCM
  2. #22 Re: Pulley
    Yes...and don't double post.
    More timing = more power...to a certain point...to where it starts knocking...then you back off.
    Stock = 16*...ideal is 18-19 from what I undertand. I'm seeing 20* sometimes...I'm crazy
  3. #23 Re: Pulley
    New Carrollton,MD
    My bad i actually am in the process of trying to get down pipe and cat so i was trying to get quick answer
  4. #24 Re: Pulley
    Chatbox brah.
  5. #25 Re: Pulley
    New Carrollton,MD
    Very true
  6. #26 Re: Pulley
    Troy OH
    little bit more in depth on timing:
    the spark plug actually fires a set amount of time before the piston reaches TDC (top dead center) because the fuel takes a certain time to burn. "timing" is actually a timing advance, meaning you can spark the air/fuel mix as the piston is still traveling upwards in hopes that the burn is complete and starts producing a force downward on the piston as close to tdc as possible, and therefore for the longest time. hence the more timing = more power. but if you go to far, you're going to induce knock. it'll spark too early and produce the downward force as the piston is still being forced up. it's measured in degrees of a complete cycle, like a circle. TDC to TDC is 360*, so if you have 18* of timing advance, you can actually figure out the distance from TDC the piston is when the spark goes off.
    hope that helps
  7. #27 Re: Pulley
  8. #28 Re: Pulley
    also a good idea to have timing increase as the engine spins faster.
  9. #29 Re: Pulley
    MA
    holy technical man ^^ agreed
    SMGPFC Member #9
  10. #30 Re: Pulley
    Troy OH
    thank you gentlemen. you guys answered most of it in the thread i started about it awhile back though. i just summarized
  11. #31 Re: Pulley
    New Carrollton,MD
    Question what is a PEM like Blue was talkin about
  12. #32 Re: Pulley
    Topeka, KS
    Ported Exhaust Manifold. Basically you take the stock manifolds and hand port them. Does it help?!?! Sometimes...
    It's a free mod. I wouldn't pay someone for some PEM's if you gave me the money to do it. You're better off getting a Performance Log (PLOG) from ZZP or Headers.
