Thread: Gear Indicator Always On?
Results 1 to 7 of 7
  1. #1 Gear Indicator Always On?
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    Hey guys. I had a Viper 5701 car alarm/remote starter installed, and ever since, my gear indicator stays on all the time. Even when I shut my car off, it stays on. Will this light burn out, or cause any drain on my battery? Does anyone have any advice on this? Thanks.
  2. #2 Re: Gear Indicator Always On?
    How long ago was it installed?
    The light will burn out, but i think it would be wise to measure the draw when the car is off.
    it should be 200 mA or lower.
    50 mA is preferable.
  3. #3 Re: Gear Indicator Always On?
    It was installed 2 days ago. Is there a way to turn it off when my car isn't on? Or will that mess with my remote start/alarm system?
  4. #4 Re: Gear Indicator Always On?
    GT Level Member Deviq's Avatar
    SE WI
    Take the car back and make them fix it.
    Quote Originally Posted by zildjian102
    .. friggin trashy people. I did stuff with their daughter
  5. #5 Re: Gear Indicator Always On?
    I'm talking to the guy. I'm going to test the battery and make sure it's drawing no more than 50mA with the key off.
  6. #6 Re: Gear Indicator Always On?
    He said he didn't touch any of the dash lights. Does anyone know how to make this light operate normally again? If my car is off, and I switch the parking light/headlight switch, it goes off. Otherwise it's always on.
  7. #7 Re: Gear Indicator Always On?
    Something is grounded incorrectly causing a feedback of power. Kinda sounds like where he hooked into the interior lighting circuit. The smallest bulb is the one that makes the connection.
  1. Fixing gear indicator
    By 2000SILVERSE3800 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-28-2009, 01:45 AM
  2. Gear Indicator on 99 gt
    By bigboibbp in forum Audio, Security & Visual Electronics
    Last Post: 10-18-2009, 11:38 AM
  3. tcs off indicator and ABS indicator both on - why??
    By RealtyCaffeine in forum General Tech Discussion
    Last Post: 08-13-2009, 06:17 PM
  4. boost indicator on DIC
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-19-2008, 10:17 AM
  5. Gear selector is a gear off after rebuild
    By skalor in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-17-2008, 11:08 PM
