Thread: mid range struggle
Results 1 to 10 of 10
  1. #1 mid range struggle
    Nov 2010
    New Brunswick Canada
    1997 gtp,
    -deleted cat
    -2 new 02 sensors
    -6 new ac delco plugs OE replacment
    -good fuel pressure
    at first my cat plugged right solid, so i bought a new cat and new res, and a new rear 02 sensor, it ran great for about an hour and started to run rough again. seemed sort of like the cat was plugged again(but not as bad), so i cut the cat open and took out the inside of the cat.
    -also checked air filter
    then replaced the front o2 sensor, it worked pretty good but started to run rough again.
    so now, in mid range(and mid boost)-2500-4000rpm the rpm;s seem to jump and the boost gauge seems to flutter between 3 and 4 lights while it does this.
    at wot im pretty sure it works right, not too sure though as i dont really know what to compare it to
  2. #2 Re: mid range struggle
    Nov 2010
    i will try to make a video to show what its doing
  3. #3 Re: mid range struggle
    does it idle steady? wires replaced recently? what's done to the car, is it stock?
  4. #4 Re: mid range struggle
    Nov 2010
    it seems like it misses at idle every few seconds(not every roation though) its inconsistant. its stock
  5. #5 Re: mid range struggle
    Nov 2010
    edit* if im parked uphill and put it in gear, every time it seems liek it misses the car rolls back ever so slightly (and only when it *misses*). this is very hard to explain
  6. #6 Re: mid range struggle
    have you been cruising along before this happens and it happens when you roll into the throttle to gain speed?
  7. #7 Re: mid range struggle
    Nov 2010
    pretty much exactly
  8. #8 Re: mid range struggle
    im going to say it is a transmission issue and not an engine issue. these cars are notorious for torque converter problems with higher mileage.
    do this, next time you think of doing it, let completely off the gas then ease back into it. if it doesnt do it then youre probably looking at some trans work. TCC lockup issues are very common.
  9. #9 Re: mid range struggle
    St. Louis
    Also check the plug wires in the back. One of them may be laying on the O2 sensor.
  10. #10 Re: mid range struggle
    Nov 2010
    yeah ive thought about tranny issues aswell, i heard about torque converters having problems, what kind of work might i be expecting? what causes the torque lock problem?
  1. spark plug gap range is best?
    By fst in forum Turbo
    Last Post: 01-31-2011, 08:50 AM
  2. Year range for MAF sensor?
    By Phurst in forum General Tech Discussion
    Last Post: 08-06-2010, 03:58 PM
  3. range rover
    By Davisgtp in forum Off Topic Discussion
    Last Post: 03-15-2010, 07:34 PM
  4. Bad MAP??? What should the range be?
    By l67fiero in forum PCM Tuning
    Last Post: 08-14-2009, 01:54 PM
  5. plug heat range....
    Last Post: 08-12-2009, 06:30 PM
