Thread: P0302 Engine misfire in cylinder 2
Results 1 to 5 of 5
  1. #1 P0302 Engine misfire in cylinder 2
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    got about 90,500 miles on it. what should i do first? hasnt had a tune up. should i start with ignition stuff? msd ignition maybe?
  2. #2 Re: P0302 Engine misfire in cylinder 2
    Bastard Reptile's Avatar
    Kansas City, MO
    Multiple misfire on cylinder 2. Start with plugs and wires.
  3. #3 Re: P0302 Engine misfire in cylinder 2
    MSD Ignition is a waste of money...also...assuming your car is stock you want stock heat range and OEM replacement plugs...example...Autolite 606's are great plugs. Also...if your wanting performance oriented...buy some PRJ Performance 10.4mm spark plug wires...pricey but you never have to buy another set again...
  4. #4 Re: P0302 Engine misfire in cylinder 2
    Nov 2010
    Illinois
    i am looking to go performance. so are those plugs good with those wires then? or are there better performance plugs?
  5. #5 Re: P0302 Engine misfire in cylinder 2
    Oct 2008
    Calgary, Alberta
    You only need colder plugs if you will increase boost, otherwise colder plugs will not get hot enough to clean themselves
    I'm going to use tr-55's in the next few weeks as the irridiums did not last nearly as long as they suggested they would (i'm running a 3.5" pulley on a 98 gtp)
  1. Cylinder Misfire!
    By AFBCamaro in forum Introductions/Noob Questions
    Last Post: 05-01-2010, 09:52 PM
  2. From misfire at cylinder 3 to a open circuit on the fuel injecter at cylinder 5
    By bbfanatic23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2010, 07:49 PM
  3. Cylinder #1 misfire and random cylinder misfire
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 07:16 AM
  4. Cylinder 3 misfire...please help!!!
    By swifty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-22-2010, 07:21 PM
  5. #4 cylinder misfire
    By JCG's-GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-11-2008, 06:16 PM
