Thread: A little help?
Results 1 to 5 of 5
  1. #1 A little help?
    Dec 2010
    Noble, Oklahoma
    Ok i just put a boost gauge in my wifes gtp,, and it's pulling around 203 of vacuum and at wot it just goes to 0. it's in the same place i ran mine to, there are no kinks,holes,leaks.... i'm stumped where is everybody running theres to?
    Boostin To A City Near You
  2. #2 Re: A little help?
    are you running it to the back vac line behind the blower??
  3. #3 Re: A little help?
    it needs to be on the nipple under the snout.
    sounds like yo have it it coming from the top tee or the TB.
    i assume by 203 you mean 20.3, thats normal vacuum but boost should be around 7 psi
  4. #4 Re: A little help?
    Dec 2010
    Noble, Oklahoma
    20# lol ok i have it to the top tee, i will change it out in the morning.
  5. #5 Re: A little help?
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Yep that would do it lol
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
