Thread: GM 85mm LS6 LQ4 MAF Mass Airflow kit
Results 1 to 20 of 20
  1. #1 GM 85mm LS6 LQ4 MAF Mass Airflow kit
    Largo, Florida, United States
  2. #2 Re: GM 85mm LS6 LQ4 MAF Mass Airflow kit
    You have a way to tune it?
    Do you have the mods really needed to support an aftermarket MAF? Not really.
    Stick with the stock one.
  3. #3 Re: GM 85mm LS6 LQ4 MAF Mass Airflow kit
    yeah i am Sponsored by a local performance shop S&R Performance
    they can tune it
    what mods would i need for it?
  4. #4 Re: GM 85mm LS6 LQ4 MAF Mass Airflow kit
    Topeka, KS
    What mods do you have currently ?
  5. #5 Re: GM 85mm LS6 LQ4 MAF Mass Airflow kit
    if you're not outflowing your stock MAF/TB then its not really worth it.
    If you were doing a Gen V swap then yeah, it'd probably be worth it.
  6. #6 Re: GM 85mm LS6 LQ4 MAF Mass Airflow kit
    I wouldn't go to an external MAF or bigger throttle body until your cammed or intercooled...your at no mod level to benefit from it
  7. #7 Re: GM 85mm LS6 LQ4 MAF Mass Airflow kit
    well im using my tax return to do a FS IC & Cam lol..
  8. #8 Re: GM 85mm LS6 LQ4 MAF Mass Airflow kit
    Why not get a ZZP Billet TB and use the stock MAF?
    Way easier...
  9. #9 Re: GM 85mm LS6 LQ4 MAF Mass Airflow kit
    Bastard Reptile's Avatar
    Kansas City, MO
    And more expensive.
    It's a neat piece, but for under $200 you can have a good N* setup from someone's demod.
    You're still going to have to tune no matter what you do if you're going to put a different TB/MAF combo on, so do what your budget calls for.
  10. #10 Re: GM 85mm LS6 LQ4 MAF Mass Airflow kit
    Quote Originally Posted by Reptile View Post
    And more expensive.
    He didn't mention a budget.
  11. #11 Re: GM 85mm LS6 LQ4 MAF Mass Airflow kit
    Kansas City, MO
    Why spend money where you don't have to.
  12. #12 Re: GM 85mm LS6 LQ4 MAF Mass Airflow kit
    It's a bolt on piece...
    And you pay for what you get, ease of installation, quality product...uses factory gaskets, sensors, etc. Your not chasing vacuum leaks on it like you would be on N* or LS1 setups that use adapters and RTV or, like Jarred had...connection issues with sensors on the N* that caused his car to not even run.
  13. #13 Re: GM 85mm LS6 LQ4 MAF Mass Airflow kit
    May 2008
    staten island,NY
    i personally liked the N* and LQ4 maf, the throttle response was better, and the car idled very quietly on a cold start instead of sounding like a vacuum cleaner like my stock tb and cone filter set up. plus you're not gonna outflow the maf like you would a stock one
  14. #14 Re: GM 85mm LS6 LQ4 MAF Mass Airflow kit
    Odessa, MO
    Actually, ZZP's billet TB is now only available without a MAF hole. It also states on the page that "You would have to install an aftermarket external MAF sensor." The pics on their page would technically not be what you would receive.
  15. #15 Re: GM 85mm LS6 LQ4 MAF Mass Airflow kit
    if the maf sensor is in a larger diameter piping then it will take more to outflow it.
  16. #16 Re: GM 85mm LS6 LQ4 MAF Mass Airflow kit
    Budget? I never buy cheap lol
  17. #17 Re: GM 85mm LS6 LQ4 MAF Mass Airflow kit
    Charles City, IA
    Nick dont weed.
    SMGPFC Two Nipple General
  18. #18 Re: GM 85mm LS6 LQ4 MAF Mass Airflow kit
    GTX Level Member real diehl's Avatar
    Salina, KS
    Quote Originally Posted by Spartan GL View Post
    He hath no budget or economical prowess. Money is no object to the Spartan GL. If you have no budget why are you building a Grand Prix?
    Good thing you changed your username too, I always thought it read spartangl like "spart-angel"
    Makes sense now...
    signature removed for inappropriate content.
    -bio
  19. #19 Re: GM 85mm LS6 LQ4 MAF Mass Airflow kit
    Kansas City, MO
    I see what you did there.....
  20. #20 Re: GM 85mm LS6 LQ4 MAF Mass Airflow kit
    Topeka, KS
    Quote Originally Posted by blueguy View Post
    What issues did he have? I think i'm having similar issues.
    I've tried two N* Maf's. My old one and a new one.
    I've looked over the adapter harness. I replaced the plug going to the maf from the stock harness.
    My aeroforce won't read it and HP Tuners doesn't either.
    Ugh...
  1. P0102 MAF mass airflow meter code low gas mileage
    By thanospl in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-20-2011, 03:25 PM
  2. mass airflow sensor issue,
    By will54768 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-26-2010, 01:19 AM
  3. Mass airflow sensor troubles!
    By Bruty74 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-06-2009, 03:33 PM
  4. Where is mass airflow sensor on 3800?
    Last Post: 11-18-2008, 11:10 PM
