Quote Originally Posted by Reptile View Post
The best and true way to tell is with some sort of scanner. The car's sensitive to the slightest changes, so even a leak you can't normally tell is there, you're likely to find by looking at the fuel trims on the scanner. It's so much easier that this is the first thing I do when I start tracing for leaks.
What should the fuel trims be at?
