Thread: starts for 1 sec. and dies, need some ideas
Results 1 to 9 of 9
  1. #1 starts for 1 sec. and dies, need some ideas
    Columbus ohio
    Well after a wiring harness meltdown in a 97 gtp, its ben hard getting it running again. The route taken is probably not the best way to go but was trying to be cheap... ugh.
    98 wiring harness and computer in a 97 car. This means that everything hooks up fine to the fuse block but not much hooks up to the car's harness that goes up under the dash. No abs...
    But... I was under the impression this stuff wasn't necessary to get the car to run. Think of it like an l67 swap into some other car. Just none of the extra crap is going to be hooked up.
    My problem is it won't start. err, it starts for about 1 second and dies, and then will repeat in about 3 min.
    Here is a video, sound isn't great, but it starts for a second then dies and won't restart.
    YouTube - MOV_0050.mp4
    I'm not sure if the car who the computer belonged to had pats or not, so it does have a pat bypass module hooked up to pin 70 on the ecm, but it doesn't change the issue.
    I'm really at a loss, any ideas what I can check?
  2. #2 Re: starts for 1 sec. and dies, need some ideas
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    It wont start because you have the wrong pcm in the car. That oldsmobile pcm wont let it run because it needs a 97 gtp pcm. Get a tuner and flash the pcm into a 97 gtp bin pcm.
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  3. #3 Re: starts for 1 sec. and dies, need some ideas
    Jul 2008
    sumter,south carolina
    security light on?
    02 GTP with mods 05 GP for DD
  4. #4 Re: starts for 1 sec. and dies, need some ideas
    Columbus ohio
    vin k and vin 1 computers are the same except for program and map sensor on the vin 1. It should still start as far as that is concerned, yeah its not the right fuel map for a superchanged engine but it should start and idle just fine. Its got a 98 harness so it does need a 98 computer, I still have the 97 gtp computer but its pin-out is totally different than the 98 harness, so it needs a 98 computer. I am planning on re-flashing a gtp program onto the olds computer when I get it running but it should still start and run with the non-gtp fuel map, its still a 3.8. I'm not just guessing about the pin-out of the olds vs. gtp computer either, I have an all-data pro membership and pin to pin its exactly the same. Unless of course i'm missing some detail here? I have read of people converting their cars from l36 grand prix gt's to l67's with the parts, and running the engine before re-flashing the l36 computer, so its basically the same thing.
    To other poster regarding security light, my 97 didnt have vats and has no security light, and the security system isnt hooked up as far as I know, unless i'm missing something? The computer is from a car that may or may not have had vats so it has a bypass module hooked up that sends pin 70 on the ecm a 50hz 5v squarewave signal to enable fuel. But it does the same thing regardless of if the module is hooked up or not.
    I wish I had an oscilloscope, i'd really like to see if that module works, and if the injectors are still pulsing when it dies.
    Does anyone know what the absolute minimum the computer needs to get the engine started? Like crank/cam position, icm, injectors, fuse block and fuel pump,... does anything at all from the cars under dash harness need hooked up other than the ignition starter signal from the ignition switch?
  5. #5 Re: starts for 1 sec. and dies, need some ideas
    GTP Level Member OrangeL67's Avatar
    Nov 2009
    Michigan
    Fuel pump resister. Bypass it and see if it runs
    VS cam build 13.01@107 316whp/ XP build #1 12.78@110 334whp/ XP build #2 12.56@113 347whp
    IS3 Cam build (Ready to put out some serious numbers)
  6. #6 Re: starts for 1 sec. and dies, need some ideas
    GT Level Member mikedinthecity's Avatar
    Apr 2009
    Southfield, Michigan
    sounds like security issue. also it does sound like other things could apply.
    2000 Daytona 500 GTP. fender well intake K&N, 180 tstat, flipped dog bones, strut2strut brace, sd headers coated n wrapped, 3in dp, 3.25 pulley, pcm tune, led tails, angel eye halos w 100 watt h1s, p&p heads, p&p m90, yella terra alum roller rockers, head studs, 8mm wires, al104s, 2007 l26, 329s hd diff, alum sub frame
  7. #7 Re: starts for 1 sec. and dies, need some ideas
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    My car Would not run with the incorrect MAP tables (had a two bar(l67) and one bar map tables (l36)) did just what you described. Which it sounds like you have a GTP 2bar map with a Onebar table. unless im missing something
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  8. #8 Re: starts for 1 sec. and dies, need some ideas
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    It seems like a problem with the vehicle theft deterrant system.
  9. #9 Re: starts for 1 sec. and dies, need some ideas
    Columbus ohio
    I'm really leaning toward the theft system as well but from what i've read it should be disabled by using the bypass module. Is there anything else that needs bypassed for the theft system?
  1. Car starts then dies
    By Rocket468 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2011, 01:08 AM
  2. PLEASE HELP!! car starts then dies
    By jdmgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-21-2010, 01:32 AM
  3. 97 gtp starts but dies
    By 50trimomni in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-26-2010, 04:20 PM
  4. Car starts then dies
    By silver2000se in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-18-2010, 06:33 PM
  5. starts and dies
    By betsgtp in forum General Tech Discussion
    Last Post: 11-30-2009, 08:56 AM
