Thread: evap leak need help
Results 1 to 4 of 4
  1. #1 evap leak need help
    GT Level Member Spartanzz's Avatar
    Dec 2010
    Lawrenceville, GA
    so i know my car has an evap leak so a friend of mine said to use a Halloween fog machine as a fog tester. So, i did and it melted part of the evap line...my main question is can the evap line be replaced with standard vaccume lines? and other question is i fi can get someone with a tuner delete the evap and catalyst codes from the pcm will it still pass emissions?
  2. #2 Re: evap leak need help
    Charles City, IA
    Yeah if the codes are deleted and the system is all there you should pass. And yes you can just your vacuum line.
    SMGPFC Two Nipple General
  3. #3 Re: evap leak need help
    Dec 2010
    Lawrenceville, GA
    ok thanks for the info just one last question. So if i order the PCM from either zzp or say intense racing and order it with the codes deleted then those should be ok to use with an emissions test then?
  4. #4 Re: evap leak need help
    Charles City, IA
    You should be, my state does not do emissions tests, I would find someone from your state to give you a for sure answer.
  1. evap and pcv
    By Biggie1720 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-04-2010, 04:42 PM
  2. EVAP Line...
    By black98gt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-14-2009, 04:28 PM
  3. EVAP Question
    By gtora69 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-25-2009, 11:11 PM
  4. egr and evap
    By blowfishRus6 in forum General Tech Discussion
    Last Post: 09-28-2008, 07:02 PM
  5. Large EVAP LEAK and FUEL CAP LEAKING?????
    By Whitehispanic in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-19-2008, 12:55 PM
