Thread: Only 1/2 boost on gauge
Results 1 to 6 of 6
  1. #1 Re: Only 1/2 boost on gauge
    GTP Level Member Austins01GP's Avatar
    Nov 2010
    Maryville, MO
    Vacuum leak. Check your lines running outta your LIM. Any cracks or even pin sized holes could cause this.
  2. #2 Re: Only 1/2 boost on gauge
    West Virginia
    That's what I thought it was too, and thank you for the reply. I researched it a little more over the net, and found out it is a bad BBV silenoid. All I did is remove the vacuum line from BBV to the BBV silenoid and fixed the problem. Forgot how good the car ran before that mess-up.
  3. #3 Re: Only 1/2 boost on gauge
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Quote Originally Posted by Austins01GP View Post
    A pin hole vacuum leak will not cause this. It would take a MONSTER leak. I mean to the point of unstable idle to loose boost.
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  1. Why is my boost gauge only reading vacuum and no boost?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2010, 02:26 PM
  2. dic boost gauge only shows half boost
    By SilvaMan61 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2010, 07:40 PM
