Thread: Coolant Leak
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #21 Re: Coolant Leak
    SE Level Member swat0712's Avatar
    Feb 2009
    Pittsburgh, PA
    Oh, and btw mine is a 97 gtp...not sure if the stuffs and different for an 06, but I'd check...
  2. #22 Re: Coolant Leak
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    I just price checked one of these parts, it was $94 at advanced....Autozone FTW!!
    and nah dude, our motors are basically the same, there are a few small changes in a series II vs a series III, otherwise pretty much everything is the same...I dunno the exact spec diffrences...
    Thanks again man, i'mma go jump on it...
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  3. #23 Re: Coolant Leak
    Feb 2009
    Pittsburgh, PA
    Wow, that's crazy if there's that much of a price difference...Yeah, I mean I figured this kind of stuff would be the same, but I didn't know and I didn't wanna steer you in the wrong direction so...No problem, good luck
  4. #24 Re: Coolant Leak
    Aug 2008
    Fayetteville, NC
    Update, I did it hours ago...No issues...did exactly what you said swat...I didn't break the bracket though...what did you break? the ear or something?
    No problems...grand prix is back to normal...
  5. #25 Re: Coolant Leak
    Feb 2009
    Pittsburgh, PA
    Great, I'm glad it worked for you...well there's two "lines" that run into the engine, one is the plastic elbow, the other is an aluminum "inlet" idk what the right term is, but that's what I broke. Since I replaced the whole assembly I had to reorder brackets for the heater hoses too because I couldn't get the old ones off..
  6. #26 Re: Coolant Leak
    Oct 2011
    Warminster PA
    I solved this well known issue, too. Readers may find my experience, pictures and parts list helpful. Check out 3.8L Coolant Leak | Daily Tweak
    I am so glad I made this repair.
  7. #27 Re: Coolant Leak
    I live here. TLSheff's Avatar
    Quote Originally Posted by IT247365 View Post
    I know your new and all, but the link you provided didn't even suggest to replace the Coolant Elbows, which were the problems in this thread originally... which also btw was started back in 2010, and ended this january.
    We do however have a How-To replace the LIM Gaskets if you searched... including pictures like the ones you posted... and the part numbers too.
    Anywho, glad you solved the problem, thanks for the extra link, and welcome
  8. #28 Re: Coolant Leak
    Oct 2011
    Warminster PA
    I know it's an old post, but I came across this post with a recent issue. In my blog, I do talk about "Water started pouring from broken Upper and Lower Heater Bypass Pipes" and have a link to a great video someone else created for youtube. I hope it helps others.
  1. Coolant Leak
    By rippemblue2005 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-10-2010, 11:30 AM
  2. Coolant leak fix.
    By Rcrevolution in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2010, 11:57 PM
  3. Coolant leak?
    By LuckyBambu in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-05-2010, 01:59 PM
  4. L36 Coolant Leak
    By JJ91284 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-14-2009, 03:41 PM
  5. Coolant leak
    By jdgaetan in forum General Tech Discussion
    Last Post: 05-31-2008, 03:24 AM
