Thread: car wont idle. have to keep it running
Results 1 to 20 of 20
  1. #1 Re: car wont idle. have to keep it running
    SE Level Member jj7ski's Avatar
    Jul 2010
    lansing, michigan
    Fuel filter has been replaced a couple months ago. I just put this engine in a few months ago so I have been replacing parts to get it to run good. I bought a used engine so I don't know exactly the mileage of everything on it. Ok ill have to rent a pressure guage from autozone then. The fuel pressure should be upwards od 50 psi correct?
  2. #2 Re: car wont idle. have to keep it running
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    Test the fuel pressure. Make sure it's around 45-50 psi. If that's normal, try cleaning your MAF sensor. I had the exact same problem, and the MAF sensor turned out to be the culprit. Make sure you use MAF cleaner or electrical grade contact cleaner.
  3. #3 Re: car wont idle. have to keep it running
    Jul 2010
    lansing, michigan
    Well I changed the pressure regulator. It took a few cranks and feathering the throttle, but now it starts up and idles fine again. I hope it the cure!
  1. wont idle down
    By tedrowkj in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-12-2010, 10:04 PM
  2. Running rich at idle, causing idle issues.
    By matt5112 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-22-2010, 09:16 PM
  3. wont idle
    By grand2000prixgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-06-2009, 07:40 PM
  4. Car wont idle help!!!!!!!!
    By GINOSGTP in forum General Tech Discussion
    Last Post: 05-10-2009, 06:30 AM
  5. 3800 wont idle?
    By runn141 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-03-2008, 03:38 PM
