quick update... more opinions please. I got around to starting on the plugs/wires today... i've only done the front 3 so far, wife had to use the car this morning, and the engine still to warm to lay on to get to the back 3. all 3 of the front plugs were VERY white on the electrode and ground strap. Cyl 3 plug had a crack in the porcelain, so maybe that explains the misfire, but maybe not. Yes i know i only changed the front 3 so far, but car still starts harder than it should on initial startup. subsequent immediate starting is normal... which makes me think it's not the other 3 plugs causing this--- it certainly is starting to act like the jimmy i used to have before the bad FPR and fuel pump were changed. anybody else have any input? (extremely white plugs indicative of lean condition from weak fuel pump?, or resulting from excess heat due to recently mixing in some regular gas?) (yes i know i need to still change the other 3 plugs)
