Thread: HELP, ive stallen and i cant start up!!!
Results 1 to 17 of 17
  1. #1 HELP, ive stallen and i cant start up!!!
    SE Level Member GTPgurl's Avatar
    Jul 2010
    syracuse, ny
    Hi, i posted this same question last winter. I thought the problem was fixed but as soon as fall hit
    the problem came back. I got my car last winter and it would go through periods of not starting and
    stalling while driving at any speed or at red lights, sometimes it will start right back up but
    sometimes it wont start for hours. Sometimes while driving the RPMs will suddenly drop to 0 and in
    less than a fraction of a second they will jump back up, like it stalled and restarted itself!? It
    doesn't seem to matter if the car engine is cold or warm, there doesn't seem to be any pattern. So
    then it went all spring and summer with no stalling but the "get up n go" power seems to come and go.
    The service engine soon light is on code p0440 evap emissions control system malfunction. The ABS and
    TRAC OFF lights are on and there is an exhaust leak. So far I have replaced the: ignition control
    module,all 3 coils, plugs, wires, alternator, battery, ignition fuse, pcv, gas cap, vacume lines
    (top left of engine), lower intake manifold gaskets, bypass pulley, and just cleaned the cam sensor
    and hardwired the fuel pump resistor sensor (it had a big peice of ceramic broken off the side).
    I am hoping to replace the crank sensor the cam sensor and the fuel pump resistor by the end of
    the week. Last night we found out that when it wont start it not getting power to the injectors
    and no spark. Any suggestions (besides getting rid of it lol) would be GREATLY appreciated. Thank
    you for any help!
  2. #2 Re: HELP, ive stallen and i cant start up!!!
    Your description is a classic crank sensor. The hiccup is a precious thing isn't it? Some of the other signs that may never show up...but you might see are a code for starting in gear etc.
    Since the crank sensor can be done with only a mirror and 10mm socket, if you'd like to save some money....I'd hold off on it.
    99% chance this is the crank sensor only.
  3. #3 Re: HELP, ive stallen and i cant start up!!!
    Jul 2010
    syracuse, ny
    ok thank you! we are doing the crank today i think. my bf is a mechanic and he has it at the shop now. i think he said he was gonna drop the side of the engine and replace a pulley thats in the way and wont come off, to get to the crank sensor. also may be replacing the cam sensor and fuel pum resistor today if possible, as a just incase.
  4. #4 Re: HELP, ive stallen and i cant start up!!!
    The balancer is in the way of the crank sensor. When he calls screaming about it, tell him the three bolts are M6 by 1.00 pitch and he'll need them to be about 75-85mm in length. (almost none of the typical puller kits have the right bolts.) In a pinch you can use 1/4" fine pitch bolts.
    Torque on the two bolts for the sensor replacement is 13ft lbs.
    Yes, definately my first time
  5. #5 Re: HELP, ive stallen and i cant start up!!!
    Jul 2010
    syracuse, ny
    ok thanks that all sounds alien to me but ill tell him im sure hell know lol
  6. #6 Re: HELP, ive stallen and i cant start up!!!
    Jersey
    i had somewhat of the same problem, turned out to be a bad fuel pump and a bad wire (fuel pump feed)
    16' wrx sti- stock
  7. #7 Re: HELP, ive stallen and i cant start up!!!
    Jul 2010
    syracuse, ny
    hey bio we are doing ity with the mirror today anything else special we should know
  8. #8 Re: HELP, ive stallen and i cant start up!!!
    Largo, Florida, United States
    Quote Originally Posted by GTPgurl View Post
    Wear your seatbeat, Don't run with Scissors, Drink your daily dose of milk.
    sorry im a dick and bored at 7am
  9. #9 Re: HELP, ive stallen and i cant start up!!!
    Jul 2010
    syracuse, ny
    the fuel pump is good we thought it might be that before but its not
  10. #10 Re: HELP, ive stallen and i cant start up!!!
    Jul 2010
    syracuse, ny
    well replacing the crank sensor today hope that fixes it
  11. #11 Re: HELP, ive stallen and i cant start up!!!
    ? thought you put the man on this a couple days ago?
  12. #12 Re: HELP, ive stallen and i cant start up!!!
    Jul 2010
    syracuse, ny
    our jack wasnt high enough to do it with the mirror we got it replaced yesterday morning though and so far so good !!!! keepin my fingers crossed
  13. #13 Re: HELP, ive stallen and i cant start up!!!
    Jul 2010
    syracuse, ny
    well i assume problem fixed, no stalling and starts up every time. it did feel like it wanted to stall yesterdey morning but thinking that is the maf will hopfully be replaced over the next couple weeks, about a foot of snow here!!!
  14. #14 Re: HELP, ive stallen and i cant start up!!!
    Enjoy your snow..I saw a few flakes (first of the year) at this end of the world.
    Glad to see you guys got this on before the snow.
  15. #15 Re: HELP, ive stallen and i cant start up!!!
    Nov 2009
    Grand haven
    Typical GP issues. BTW we got 12 inches here.
  16. #16 Re: HELP, ive stallen and i cant start up!!!
    GT Level Member afallucco's Avatar
    Ohio
    I had the same issue when my car wouldn't start warm. BTW I'm in Buffalo right now and its pushing about 3-6 feet depending on where you are.
    2004 Grand Prix GTP
    |FWI | HP Tuner | 1.9 Rockers | SD Headers | 3.5MPS | 97-03 control arms w/GMPP sway bar|
    Planned soon: s3x, custom ported heads, IC
    Thug life, that's how we live.
  17. #17 Re: HELP, ive stallen and i cant start up!!!
    Jul 2010
    syracuse, ny
    very happy to not be stalled and stuck out in the snow !!! btw holy cow 6 feet of snow!!! i saw they had the thruway closed in buffalo i just got back from ohio last weekend, just in time lol
  1. No start. Need help!
    By Phurst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-25-2010, 09:09 AM
  2. where to start
    By Jakegday in forum PCM Tuning
    Last Post: 08-04-2009, 12:51 AM
  3. Car tries to start but will not.
    By black2000gtp in forum General Tech Discussion
    Last Post: 08-01-2009, 05:09 AM
  4. where to start
    By bitterpill in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-16-2009, 10:46 PM
  5. no start
    By betsgtp in forum General Tech Discussion
    Last Post: 06-05-2009, 12:19 AM
