Thread: Stalling And Dying
Results 1 to 13 of 13
  1. #1 Stalling And Dying
    st paul
    Car starts up fine. When i put it into drive it and put my foot on the pedal it dies. I put it into neutral at stops and rev it up to 1500 rpms and throw it into drive and it doesnt die. i cleaned the throttle body and that didnt seem to help. My car died every time i was at a stop and tried to drive. any thoughts of what i should be looking at? Help is greatly appreciated.
  2. #2 Re: Stalling And Dying
    It possible that your cps sensor is bad.
    cps = crank position sensor
  3. #3 Re: Stalling And Dying
    st paul
    i didnt get a check engine light though. The car dying at a stop is sporadic. It'll happen one day and than the next it wont die at all.
  4. #4 Re: Stalling And Dying
    the cps wont throw a code
  5. #5 Re: Stalling And Dying
    st paul
    why not? how am i suppose to know if its bad or not?
  6. #6 Re: Stalling And Dying
    im not sure why gm made it that way
  7. #7 Re: Stalling And Dying
    st paul
    im pretty sure if it was bad it would throw a code. I dont have a DIC, but i dont think thats where the check engine light is.
  8. #8 Re: Stalling And Dying
    st paul
    From the ignition control module, the PCM uses this signal to calculate engine RPM and crankshaft position at engine speeds above 1200 RPM. The PCM also uses the pulses on this circuit to initiate injector pulses. If the PCM receives no pulses on this circuit, DTC P1374 will set
  9. #9 Re: Stalling And Dying
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    unplug the Maf and see if it runs better
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  10. #10 Re: Stalling And Dying
    st paul
    ill give that a shot and respond tomorrow.
  11. #11 Re: Stalling And Dying
    st paul
    would running a scan help? when im in drive and stopped the whole car shakes very badly. i dont know if that give it you any hint.
  1. Starting then dying
    By firefighter6180 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-09-2011, 10:21 PM
  2. Intermittent dying problem with 00 GTP
    By ls6velless454 in forum General Tech Discussion
    Last Post: 04-08-2010, 12:11 PM
  3. question about car dying
    By clovewell in forum General Tech Discussion
    Last Post: 02-04-2010, 04:11 PM
  4. battery dying
    By jaketrey32 in forum General Tech Discussion
    Last Post: 07-29-2009, 05:10 PM
  5. Car keeps dying
    By jakeeck in forum General Tech Discussion
    Last Post: 02-19-2009, 12:26 AM
