UPDATE 9/21/11: WHATS NEXT? UPCOMING
SKIP AHEAD TO THIS THREAD FOR NEW POSTS
>>>NEW UPCOMING PLANS<<<
This thread is directed to my 2004 GP GTP CompG and it's modifications.
I got this car with 7,xxx miles on the odometer, in February of 2007. It was all stock with Enkei 10 spoke alloy wheels.
To this day, it has 68,xxx miles. This car is daily driven.
-HPTuners Pro VCM suite
-DHP
-Comp Cam's X-P hot camshaft (212,224/.325.335/116LSA)
-Rollmaster double roller timing set (properly machined)
-105# valve springs
-qwik port stock heads (casting #8)
-ARP head studs
-Cometic MLS .052" head gaskets
-ZZP MPS 3.0"
-ZZP 2.25" aluminum A2W intercooler system w/ silicone hoses & bosch pump (100% resealed/leak free)
-ZZP billet fuel logs
-Mototron 80#/hr (800cc) injectors
-E85 (summer) / 93 octane (winter)
-Poly upper engine mounts
-ZZP billet aluminum upper engine supports
-Poly lower engine mount
-Poly transaxle mount
-ZZP stainless headers
-ZZP 3" 304SS downpipe
-ZZP 3" 304SS catback exhaust
-30" 304SS Magnaflow resonator
-KYB GR-2 gas shocks
-SSC lowering springs w/ anti-pogo washers
-GXP brakes
-Xenon HIDs 10,000k
-Aeroforce scan gauge
-AEM vac/boost
-AEM wideband o2
-AEM fuel pressure
Progress:
In-car tear down
Engine is out
Cam install
Block, heads and timing set
Valvetrain, front cover and intake
Money shots
Engine is in, and buttoned up
Gas shocks, lowering springs & GXP brakes
85mm LQ4 MAF & Mototron 80#/hr injectors
ZZP I/C overhaul...new core, plates resealed, new hoses
3.0" pulley IDLE VIDEO
12 second pass, 110+ MPH @ GREAT LAKES DRAGWAY
NEW UPCOMING PLANS
