Thread: So I spun a rod bearing!!!! Advice wanted!!
Results 1 to 14 of 14
  1. #1 So I spun a rod bearing!!!! Advice wanted!!
    Nov 2008
    ohio
    It seems like a spun a bearing yesterday.
    I started to unhook everything so I could pull the motor and might get to it tonight.
    I never figured I would have the motor out and cam was the first thing that came to my mind.
    If I get a cam it would be the S1X, but what else would I have to do to it? Would it only require new valvesprings?
    And could I drive it without a tune for a while. Im in Toledo, Oh which is right in between ZZP and Intense, but they are both about 2 hours away. Or could I get a decent mail order tune.
    If I decide to cam I will put headers on it, could I drop to a 3.4 pulley then?
    Sorry for all the questions!!!
    04 Grand Prix GTP (Wizaired, 3 inch downpipe)
  2. #2 Re: So I spun a rod bearing!!!! Advice wanted!!
    Portland Oregon
    Parts list
    Gasket set, cam, cam bolt and crank bolt, viton valve seals, springs, retainers, rocker bolts. I would get a new timing chain and tensioner since you'll be in there anyway. You'll be fine to drive it for a while as long as you don't get on it. It'll probably throw a p0300 code for random multiple misfire until you get it programmed out.
  3. #3 Re: So I spun a rod bearing!!!! Advice wanted!!
    3.4 would probably be good with a plog in there as well.
    But run the 3.8 to break the motor in.
  4. #4 Re: So I spun a rod bearing!!!! Advice wanted!!
    Charles City, IA
    You dont need a cam and crank bolt.
    SMGPFC Two Nipple General
  5. #5 Re: So I spun a rod bearing!!!! Advice wanted!!
    you need loctite.
  6. #6 Re: So I spun a rod bearing!!!! Advice wanted!!
    Charles City, IA
    You dont even need loctite really just get them good and tight. If you want tho put some blue loctite on it.
  7. #7 Re: So I spun a rod bearing!!!! Advice wanted!!
    Donating Users iroc2's Avatar
    Jul 2010
    Lansing IL
    or find the torque specs
    SMGPFC # 008 -White 1995 Grand Prix SE: tinted tails, Flowmaster 40 Series mufflers with resonating tips. much more to come eventually
    Quote Originally Posted by Xorbex View Post
    I almost beat the man but murphy showed up.
  8. #8 Re: So I spun a rod bearing!!!! Advice wanted!!
    Charles City, IA
    I have the torque specs, but they do not really need to be followed for those bolts.
  9. #9 Re: So I spun a rod bearing!!!! Advice wanted!!
    crank bolt = tight as **** lol
  10. #10 Re: So I spun a rod bearing!!!! Advice wanted!!
    Charles City, IA
    burp it with the impact twice and good to go.
  11. #11 Re: So I spun a rod bearing!!!! Advice wanted!!
    Loctite yes.
    Crank bolt...you basically know its tight when you have a hernia.
    Cam bolt...I loctite also...I honestly feel safer knowing it doesn't have that slight change of GOING ANYWHERE. As for the pulley size...a S1X, Header, GenV, tuned car...should run damn well on a 3.4". Start with a 3.8" for good measure and be sure to pick up an MPS system if you haven't already.
  12. #12 Re: So I spun a rod bearing!!!! Advice wanted!!
    Nov 2008
    ohio
    I just wish some one could tune it for me local, not 2 hours away
  13. #13 Re: So I spun a rod bearing!!!! Advice wanted!!
    GTX Level Member 97gtsc's Avatar
    Jul 2008
    Livonia MI.
    I kno a guy in sterling hts. MI. He tuned mine and others in the area!
  14. #14 Re: So I spun a rod bearing!!!! Advice wanted!!
    Nov 2008
    ohio
    ended up being 4 out of 6 rod bearings....damn dex-cool
  1. How much is an 04 comp g worth with 120k and a spun bearing?
    By CandyBlueta in forum Off Topic Discussion
    Last Post: 11-18-2010, 02:21 PM
  2. maybe bad bearing?
    By mvp2765 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-12-2009, 08:26 AM
  3. Spun a bearing
    By GTP4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-14-2009, 12:05 PM
  4. Rod bearing took a S***
    By speedemongtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-25-2009, 08:03 AM
  5. Spun bearing! swap to L26??
    By gixer2000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-05-2008, 08:35 AM
