Thread: horrible gas mileage!
Results 1 to 20 of 23
  1. #1 horrible gas mileage!
    SE Level Member rah575554eg's Avatar
    Apr 2009
    Alliance, NE
    I have been recently been getting bad gas mileage on my 2003 gtp. I have changed the fuel filter and fuel pump a year in half ago. I just got done changing the spark plugs from Tr8 ngks which were to cold for my setup to a hotter TR6 plugs and I changed the O2 sensors today. It still is get around 10 to 12 mpg in town on normal driving. I don't know what else to check. Thank you!
    2003 Pontiac Grand Prix GTP 3.2" mps, SSIC, Ported M90, Ported LIM, ported tb, K&N Intake, Headers, 160 stat, AC rapid fire plugs and DHP custom tuned pcm
  2. #2 Re: horrible gas mileage!
    Jul 2008
    sumter,south carolina
    o2 sensor possibly.
    02 GTP with mods 05 GP for DD
  3. #3 Re: horrible gas mileage!
    Nov 2010
    surprise, az
    what is normal gas milage for a stock gtp 97'
  4. #4 Re: horrible gas mileage!
    Jul 2008
    i have headers and open cone intake and get up to 30mpgs on highway... 24-25 in town driving.
  5. #5 Re: horrible gas mileage!
    You can find my build thread somewhere...but I have a huge cam/heads setup with 3.29 gearing...I get over 30 mpg's quite often on the highway. Also...TR8's?
    TR6's are too cold...those are for 3.2"-ish setups. Get Autolite 104's and gap em at .050". The end. See how that helps. Also...if you have headers, do you have a rear o2? If not...there is your issue.
  6. #6 Re: horrible gas mileage!
    Apr 2009
    Alliance, NE
    I just put in an oxygen sensor yesterday But it did not help with any.
  7. #7 Re: horrible gas mileage!
    I'm talking rear o2
  8. #8 Re: horrible gas mileage!
    Apr 2009
    Alliance, NE
    I do have a rear o2 sensor on my my headers
  9. #9 Re: horrible gas mileage!
    Charles City, IA
    Thats your problem. Your car is drowning its self with fuel to try and test the cat and is seeing no response from the rear 02. Put one in and use the sparkplug non fouler trick. Also thanks for the tech tip.
    SMGPFC Two Nipple General
  10. #10 Re: horrible gas mileage!
    He can't do that without a custom tune...since its an '03. He can have no cat...but NEEDS the rear o2...not a sim or fouler.
  11. #11 Re: horrible gas mileage!
    Charles City, IA
    You use the 02 with the fouler, it just pushes it out of the exhaust path more so it will see more oxygen and when the computer runs the test it will also switch to rich, it will work fine. Also this should be in the gen tech section mr. mom.... i mean mod.
  12. #12 Re: horrible gas mileage!
    hows the FPR?
  13. #13 Re: horrible gas mileage!
    I've tried the o2 with both the fouler and the sim. From my experience...it runs best with sittin' in the factory position Amsoilmang
  14. #14 Re: horrible gas mileage!
    Windsor (ON) Canada
    So your saying the non fouler "trick" really doenst work? I have the non-foulers on (getting about 15-16mpg city) and been debating just taking them off.
  15. #15 Re: horrible gas mileage!
    Nov 2010
    Atlanta Ga
    Do you think the 160 thermostat could also be harming fuel economy?
  16. #16 Re: horrible gas mileage!
    GTX Level Member cerick08GP's Avatar
    Quote Originally Posted by kevins View Post
    You are guaranteed lower mpgs, no way around it. It is just a question of how much of a hit you will take. Just to throw it in, your fan settings will affect the severity also.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  17. #17 Re: horrible gas mileage!
    Vancouver, WA
    So having no cat doesn't help gas mileage on these cars? I've been running no rear o2 with no car since June on my 98, I get 16-18 city and about 30 highway.
  18. #18 Re: horrible gas mileage!
    headers will net you more.
  19. #19 Re: horrible gas mileage!
    Quote Originally Posted by footballplaya3k View Post
    Because you have a '98...they don't care about rear o2's, problem in question is a newer year car which the rear o2 WILL affect the MPG's.
    So will a huge cam, and a huge throttle body, and bigger injectors, and ported heads, and a custom tune, and a higher gear ratio.
    BAM.
  20. #20 Re: horrible gas mileage!
    Stop being sarcastic.
    you know simple flow mods improve gas mileage.
  1. Car getting horrible MPG
    By Mercenary in forum General Tech Discussion
    Last Post: 02-02-2011, 10:42 PM
  2. New headlight output HORRIBLE need help (pics)!
    By Frank217 in forum Visual/Body Modifications
    Last Post: 08-08-2010, 05:58 PM
  3. Engine making horrible noise.
    By starscr33m in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2009, 12:24 AM
  4. polished aluminum is a horrible disease
    By turbocharged406sbc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-23-2008, 11:11 AM
  5. Check engine light and horrible miss...
    By JCG's-GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-05-2008, 07:53 PM
