Thread: Fuel gauge
Results 1 to 20 of 37
  1. #1 Fuel gauge
    Donating Users BoostnBlackGTP's Avatar
    Waterloo, Iowa
    ok so ever since i got my car int he spring time my gas gauge has never went to full even when i fill it up.
    It goes about 3 notches below FULL. That is as high as it gets. I put a brand new fuel sending unit and pump in it and tht did nothing. anyone know what i could do?
  2. #2 Re: Fuel gauge
    Charles City, IA
    You gauge is probably bad.
    SMGPFC Two Nipple General
  3. #3 Re: Fuel gauge
    Waterloo, Iowa
    so what do i do? try gettin a guage from a junkyard? and when i had the sender out i tryed movin the float up and down and when i did that the guage went all the way to full but why wont it do it in the tank?
  4. #4 Re: Fuel gauge
    Are you sure the tank is actually full?
    Are you sure the fuel pump is installed correctly? If it wasn't in the right position that could happen. (too high)
  5. #5 Re: Fuel gauge
    Waterloo, Iowa
    well how much do our tanks hold? and yes it was installed corrctly cuz i could not get it in so i had a tech help me at my work
  6. #6 Re: Fuel gauge
    what year is your car?
    97 is 18 gallons, 98-03 is 17.5
  7. #7 Re: Fuel gauge
    Waterloo, Iowa
    and that is from Empty? bcuz when i fill up form empty i dontt hink i get that much
  8. #8 Re: Fuel gauge
    thats the full capacity.
    unless your tank is bone dry you'll never put that much in.
  9. #9 Re: Fuel gauge
    Waterloo, Iowa
    if i rememebr right when i am on EMPTY i only get in about 10 or 11 gallons tops...
  10. #10 Re: Fuel gauge
    Waterloo, Iowa
    so is this sayin a need a new tank?
  11. #11 Re: Fuel gauge
    sounds like the sender isn't aligned properly. or isnt seated all the way down.
  12. #12 Re: Fuel gauge
    Waterloo, Iowa
    the sender is sealed all the way down but when i fill up from EMPTY i still only get about 10 gallons in and it wont go any more. i tohught u said its a 17 gallon tank
  13. #13 Re: Fuel gauge
  14. #14 Re: Fuel gauge
    Waterloo, Iowa
    so basically just work witht he sending unit? or what should i do in this situation haha bcuz it also whines really loud once it warms up it seems like
  15. #15 Re: Fuel gauge
    try a new gauge or fool around with the sender
  16. #16 Re: Fuel gauge
    GT Level Member sic6's Avatar
    san marcos, tx
    Double check the arm on the sending unit. It could have gotten bent and is partially getting stuck somewhere on the bucket.
  17. #17 Re: Fuel gauge
    GTP Level Member lambokit's Avatar
    Apr 2009
    Radford, Virginia
    I may actually have a gauge from a 00 model if you need one. Just let me know.
    Lambokit to be built!!!!!
  18. #18 Re: Fuel gauge
    Waterloo, Iowa
    how much u wantin for it lambo?
  19. #19 Re: Fuel gauge
    Apr 2009
    Radford, Virginia
    Don't really know what it's worth. I dunno how about $10 plus shipping? Just let me know. I'll go down to the garage and make sure I have it.
  20. #20 Re: Fuel gauge
    Waterloo, Iowa
    yes let me know and how many miles r on it once u find out
  1. Fuel Gauge
    By agent505 in forum General Tech Discussion
    Last Post: 05-06-2010, 11:07 AM
  2. Fuel Gauge
    By racecardude310 in forum General Tech Discussion
    Last Post: 01-22-2010, 04:56 AM
  3. Air/Fuel gauge help
    By WayneG99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-26-2009, 02:59 PM
  4. fuel gauge help!!
    By momo29 in forum General Tech Discussion
    Last Post: 03-05-2009, 08:11 PM
  5. 00 GT Fuel Gauge
    By cherm45 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-13-2009, 05:50 PM
