Thread: Map sensor reading goes from 35kpa to 65kp every 6 seconds?
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #21 Re: Map sensor reading goes from 35kpa to 65kp every 6 seconds?
    carb cleaner works well, it lowers the engine idle when you've found the spot.
  2. #22 Re: Map sensor reading goes from 35kpa to 65kp every 6 seconds?
    Apr 2009
    methuen
    Ok I will give it a try and post back. We did remove the egr tube apon removal of the lim. Is there a better way to seal that better if it is leaking? Sorry for the questions. haha stupid car!
    1.9 Rockers- 42.5 injectors- 3.4" mps- Wizaired 104s- 180*- PRJ 10mm wires- SD headers 3" DP- Hp tuner- Dynotech stage 2- 3.29s 1'' chain
  3. #23 Re: Map sensor reading goes from 35kpa to 65kp every 6 seconds?
    Apr 2009
    methuen
    Little update worked on the car for a little while. Found the vac hose that runs around to evap canister was slit open. replaced that line. There is stll a hissing sound in the rear after i replaced it. I going out tomorrow to buy some more vac lines and see what happens and replace the vac lines back there.
  4. #24 Re: Map sensor reading goes from 35kpa to 65kp every 6 seconds?
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    sweet glad to see your finding them. copper rtv works well on the egr if thats leaking
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  5. #25 Re: Map sensor reading goes from 35kpa to 65kp every 6 seconds?
    Apr 2009
    methuen
    Ok got all my vac lines squared, also found one of the tees had a hairline crack in it. vac is at 19 and at decel it goes to about 25. But now i have a new problem. The oil cap on the front valve cover whistles really loud after about 5 mins of running. When removing there is a lot of vacuum and the noise goes away. I put the oil cap back on and the whistling sound comes back. Do you guys Have any idea what might be wrong.
  6. #26 Re: Map sensor reading goes from 35kpa to 65kp every 6 seconds?
  7. #27 Re: Map sensor reading goes from 35kpa to 65kp every 6 seconds?
    your PCV is blocked. change the PCV valve.
    posted in your other thread as well...might not be a bad PCV.
  8. #28 Re: Map sensor reading goes from 35kpa to 65kp every 6 seconds?
    Apr 2009
    methuen
    Thanks guys for all your help. When I replaced the TB gasket on ther side of the spacer i have. I installed it backwards. So it was blocking the pcv port. What a dope I am. haha I hope i didnt ruin anything by having it that way.
  1. Exterior Temperture Sensor reading OC
    By SNeitzel in forum General Tech Discussion
    Last Post: 10-01-2010, 11:28 AM
  2. Car shuts off after a few seconds of running
    By Kissner in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-17-2010, 10:51 PM
  3. Car kills out after a few seconds
    By Kissner in forum General Tech Discussion
    Last Post: 03-16-2010, 07:32 PM
  4. Car starts but stalls after 2 seconds
    By cartooz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-26-2009, 06:18 AM
  5. Please take 2 seconds and vote for us to get a strip
    By Z28 in forum Off Topic Discussion
    Last Post: 07-27-2009, 06:19 PM
