Thread: Weird Issue
Results 1 to 20 of 38
  1. #1 Weird Issue
    Was driving around this morning when the ses light came on, hooked up my code reader and the car was throwing the P301 code random misfire cylinder #1, I have fairly new plugs and wires, both were replaced in August, and I replaced all the coils in June. The only thing I can think of it being is a fuel injector. Is this where I should start? Is there anyway to test the coils?
  2. #2 Re: Weird Issue
    GT Level Member rmcardle3's Avatar
    Houston, TX
    Swap the bottom coil with one of the other coils. If the P0301 moves to another cyclinder (say P0302-6) problem isolated. Hope this helps.
    2000 GRAND PRIX GTP (Sedan)
    MICHELIN Pilot® Sport A/S Plus 245/50 ZR16 97W M+S
    Cone Intake, SD Headers
  3. #3 Re: Weird Issue
    Good idea. They are used coils co it may be very likely that one died.
  4. #4 Re: Weird Issue
    Swapped two of the coils around and still misfire cylinder #1.
    I noticed it only pops up when I'm driving down the highway, I can clear the code and drive around town all day long no problem, but I take a trip down the highway and the ses light starts flashing at me.
  5. #5 Re: Weird Issue
    Alright swapped around some injectors and replaced all the orings, and still misfire cylinder #1....
  6. #6 Re: Weird Issue
    have you pulled the plug and looked at it yet?
  7. #7 Re: Weird Issue
    Looks like a spark plug.
  8. #8 Re: Weird Issue
    Akron Ohio
    What brand of wires? switch them around too.
  9. #9 Re: Weird Issue
    Omnispark or whatever from Oreilly's. I order a set of Bocsh wires because all any of the parts stores in town had in were the cheepos.
  10. #10 Re: Weird Issue
    The cheepos that have the lifetime warranty are the best.
  11. #11 Re: Weird Issue
    Yeah those are the ones I have now, Matt and a few others in chat were saying that they went through 2-3 pairs of the cheepos before they finally got the premium ones.
  12. #12 Re: Weird Issue
    I just got NGK wires.
    Crappy tire has disco'd bosch in favour of NGK.
  13. #13 Re: Weird Issue
    We have Duralast wires at Vatozone...
    Perfect on a few 3800 cars I've done a tune up on.
  14. #14 Re: Weird Issue
    Now another problem has sprung up, where the fuel lines connect to the fuel rail I am leaking fuel........ I don't know if this was leaking before but it would explain my bad gas mileage and the reason I could smell fuel, reason I replaced the orings on the injectors. I don't even know where to start with that one........... Seems I try to fix one thing something else breaks..........
  15. #15 Re: Weird Issue
    Nov 2009
    Grand haven
    Disconnect the connection and replace the O ring in there. They get old and brittle. I think they are .70 cents. Autozone has them.
  16. #16 Re: Weird Issue
    Ok I didn't think you could replace the seal, thats what I noticed after taking apart.
  17. #17 Re: Weird Issue
    I'm sure you could RTV it...but thats the ghetto way of getting sh1t done...
  18. #18 Re: Weird Issue
    LOL at nick...
    You can buy a new quick disconnect which is around $10 here or go to autozone and fine the HELP! o-ring pack.
    then struggle to get them out of your disconnects....
    I like the replace the whole thing deal.
  19. #19 Re: Weird Issue
    Actually it was really easy to replace the o rings I did both of the lines since i was already down there.
    But after all that and the new wires I am still getting the P0301 misfire cylinder #1..... I think a icm is the next thing I'm gonna check.
  20. #20 Re: Weird Issue
    Hurray for proper tools.
    Next item is usually the injector, not the ICM.
    Unless you have a bunch lying around like I do...
    Try moving the injector or better yet ohming it out first.
    16 ohms is stock IIRC.
    Or 15.5?
  1. First Run on the track, and weird shifting issue
    By speedy2 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-12-2010, 03:41 PM
  2. weird cooling issue
    By Spazztic2003 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-29-2010, 05:44 PM
  3. weird car issue
    By NashGT02 in forum General Tech Discussion
    Last Post: 07-29-2010, 09:16 AM
  4. Weird Sub Issue
    By dagger in forum Audio, Security & Visual Electronics
    Last Post: 05-20-2010, 10:11 AM
  5. Weird ABS issue
    By Toofastgs in forum Brakes/Suspension/Chassis
    Last Post: 06-24-2009, 12:06 AM
