I know everyone is probably tired of hearing about stalling problems, but I haven't found any threads that has the same problem that I am having. I have a 97 GTP. After one of my coil packs went out, I replaced them with MSD Blaster Coil packs. A couple days later she stalled out on me while pulling off from a light. No sputtering or nothing like that. It was like the key was turned off. Fired right back up and no problems. Happened again about a week later and same thing. So I pulled the coil packs off and cleaned the Ignition control module. Ran fine for almost a month. Then when I left my house going down a side road, it shut of again. This time I wasn't in traffic, so I could look around a minute. The radio and shift indicator light ond the instrument cluster were the only things on. Cut the key off and it fired right back up. When I got back home, I turned the key back one notch of run and it shut down like it did when it died on me. Radioo and indicator light was the only thing on. Has anyone else had this problem and does it sound like the ignition switch going bad? That is what I am thinking, but want others take on it. Tired of buying parts that don't fix my problem and it's kinda scary when you pull out, your car shuts off and there's cars coming at you. Any halp you can give me will be greatly appreciated. Thanks
