Thread: knock sensor problem??
Results 1 to 8 of 8
  1. #1 Re: knock sensor problem??
    SE Level Member Justin48's Avatar
    Groton, CT
    start with baisic tune up... see you did your wires but did you do your plugs... read the plugs see what each hole tells you. i X2 4thgen but get a scanner and look at the tps% if the engine is not running you should see a steady increase of % as you press the pedal. if it jumps around then it is bad... but they are kinda pricy so that is why i say start with the cheep parts if you are going to do a "throw a part at it and see if it fixes it"
    zzp mps 3.2-3.4", prj intercooler core, bosh pump, zzp stage 3 front mount, xp cam, 130# springs,double roller chain, 42.5# injectors, sd headers, 4" fwi, modified prj tune(inprogress) performance shift add, aem wide band, aeroforce.
  2. #2 Re: knock sensor problem??
    GTX Level Member colindunn's Avatar
    Aurora, IL
    okay but the throttle response is nice and completly normal from 40% throttle and up. i can use a snapon ethos scanner from school and look at the tps though.
    just did the plugs too. ac delco direct replacement gapped to .55
  1. knock sensor and airbag light
    By 08pontiacgxp in forum 5.3L V8 (LS4)
    Last Post: 09-25-2010, 11:26 AM
  2. Help! Rear knock sensor
    By cav in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-26-2010, 12:26 PM
  3. Knock Sensor
    By SuperCharged6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-08-2009, 01:51 PM
  4. knock sensor?
    Last Post: 10-20-2008, 12:19 AM
