Gotcha. Putting that many dollars into the motor, I'm sure I wouldn't leave them untouched.
Get ahold of Tazmic on WCCGP and he can clue you in.
He is in the dead middle of doing his twin charge set up.
Whole motor up, and tranny.
As far as the rockers and cam go....Were you just trying to go with both the rockers and cam to gain more lift??...just go with a bigger cam if thats the case...will probably be cheaper too![]()
I was thinking of going with the stage 6 kit from 3800performance. Do you know of anyone that has ran thiis set up. I thought it was a pretty good deal with everything it comes with. And if there was anything I didn't use, I could sell and make some money back. Plus some other mods to go with it.
Nope, so the rockers and the cam come in the kit then??...and yea you could for sure make some money back on some of the parts that are in the kit that would not be used im sure.
and when were talking about rockers and say it would be pointless to have them with a aftermarket cam...we mean rockers that are a higher ratio than stock...not 1.66 aftermarket rockers...(wich is the stock ratio)
