Thread: please help!
Results 1 to 3 of 3
  1. #1 please help!
    colorado springs
    I have a regal gs cluster that is wigging out. My temp guage reads backward, the gear selection is dim and says im in 2nd and 1st at the same time, and the info center is out. any ideas?
  2. #2 Re: please help!
    If it's just dim, that's the resistor fix. I got your back there. If it's wigging out with backwards temp etc... swap out the cluster. Taht'll be your best bet.
    What year is it? I have a 98 here that's good with 120 on the odo. Holler if you need the write or if the cluster is the right year. 99 ... actually I have one of those too. 99's are different than 97/98.
  3. #3 Re: please help!
    colorado springs
    well i have a 97. Why do you say swap the whole cluster if the temp guage is read backward? Is there no fix for that? I know i can fix both dig displays. I got one from a guy locally, but it has the perf shift light in a diff spot, the speedo was dead, and the prnd display was dim. I think it was from a different year as you wer saying because of the perf shift location and it also had the little notification to hold for odo reset printed on the face.
