Thread: SS M90 misfiring due to tune?
Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
  1. #21 Re: SS M90 misfiring due to tune?
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    With my Intense PCM, my STFT is -0.7 to 4.6 at idle. My LTFT is 12.5 at idle. I'm contemplating just biting the bullet ad getting HP tuners and learn it myself. This is so frustrating.
  2. #22 Re: SS M90 misfiring due to tune?
    You'd also want to invest in a wideband.
    Although arent you trying to sell one?
    Either way. Those tunes are wrong or you have mechanical issues.
    STFT's dont mean much. Pay attention to the LTFT's.
  3. #23 Re: SS M90 misfiring due to tune?
    Yea maybe I'll just keep it. I don't have a spot left in my gauge cluster though. Need to find a place to mount it.
  4. #24 Re: SS M90 misfiring due to tune?
    HUD pod or in the cubby below the ashtray?
  5. #25 Re: SS M90 misfiring due to tune?
    Bastard Reptile's Avatar
    Kansas City, MO
    MAF table could be off by that much too.....I've seen it that way. But even with the Intense pcm, it suggests something isn't right.
    Kinda off the wall, but have you checked the O2 sensors? If it's going bad, it can throw a tune off also.
  6. #26 Re: SS M90 misfiring due to tune?
    Quote Originally Posted by Reptile View Post
    Hmmmm. I'll have to look into the O2 sensors. Reptile, where is your shop?
  7. #27 Re: SS M90 misfiring due to tune?
    Kansas City, MO
    I'm near Kansas City, MO
  8. #28 Re: SS M90 misfiring due to tune?
    my LTFT's were all around 12 all the time.
    Even with no vac leaks, exhaust leaks, brand new O2.
    Tune was off since it was tuned with an exhaust leak first time around.
  9. #29 Re: SS M90 misfiring due to tune?
    Wouldn't it throw a code if the O2 sensor had a problem?
  10. #30 Re: SS M90 misfiring due to tune?
    Kansas City, MO
    Well sure, it can, and it should, but I've seen where they won't throw a code. It mostly does it when it doesn't "switch" like it should. What I was getting at, is that I've seen an O2 sensor make a difference of +- 8 just by switching. Denso, Delco, they seem to read different.
    But then again, I've seen stock tune cars, factory everything go +12 on a scan.
  1. 3800 misfiring
    By 91xc400 in forum General Tech Discussion
    Last Post: 08-09-2010, 12:26 PM
  2. Misfiring
    By Kazmoe in forum General Tech Discussion
    Last Post: 02-20-2010, 07:10 PM
  3. Misfiring
    By Dropped GP GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-13-2009, 07:15 PM
  4. need help!! misfiring???
    By icolex1 in forum General Tech Discussion
    Last Post: 02-26-2009, 03:49 PM
  5. Misfiring?
    By hotshot in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-05-2008, 09:33 PM
