^^That's a good one...you can also see if the Boost Bypass is working right...try swapping it out with another one or buying one from ZZP on teh cheap. That is one of the causes of "low boost" also...that and the fact you've got a 3.4" with headers...but you should still be seeing about double that psi @ WOT.
