I'd need to see someone do 3 pulls with marty's core after the engine is fully heat soaked and another three with say a ZZP or WBS core.
Also: monitoring I/C coolant temps would be useful as well.
But i'd like to see his dyno regardless.
It would need to be independent I know that. To much of the "well ZZP already tested everything before" any time an I/C comes about. Like the guy that was making an I/C out of laminova (sp) cores, he got jumped on left and right about how it doesn't work for what ever reasons. Independent is the way to go on the testing tho.
I found out from William Stewert that he was going to be getting coolant temps when he finished his I/C stuff cause as of right now he has the IRC core but uses a ZZP FMHE so he is going to be going with a custom FMHE from IRC and doing temp measurements at that point.
Thinking of that where is the best place to set up temps readings for an I/C? I asked William and he said he is not sure where most do it but he was going to measuring at the FMHE cause of his set-up. Not sure why that is but it did make me wonder where the best place actually is.
