I'm going to be doing a GenV swap on a WBS Gen3 IC and Gen3 LIM with N* TB. I'm running a breather now with the current Gen3 setup, but want to get rid of it and have functional PCV with the GenV. I've read through many threads and think I have the right idea on how to do it. Please let me know if I'm on the right track.
The WBS core has holes in the back by the PCV valve, so first thing would be to drill a hole in the LIM to match up with the hole in the bottom plate.
Then, run a hose from the vertical nipple on the back of the GenV to a fitting in the N* adapter plate (after TB blade).
Then, tap the side of the front valve cover, and run a hose from that fitting to the brass fitting in the N*TB (after MAF, before blade).
Will this setup work while being able to keep the PCV valve in the blower like stock? Should I run a catch can from the rear or is there not a whole lot of oil coming from the nipple in the blower? Thanks for any advice
