Thread: hey is this pulley ok for my ssm90 setup?
Results 1 to 18 of 18
  1. #1 hey is this pulley ok for my ssm90 setup?
    GT Level Member DBGP's Avatar
    Vancouver, BC, Canada
    hey my ssm90 kit awaits to be put on my car. I got a gtp belt setup for it, and i have a stock gtp pulley (3.5 correct me if im wrong.) Would that pulley be fine? My mods will be 2.5" dp, ubend delete, mufflers, CAI, ported LIM and s/c. If its too small i would just order a ssm90 pulley from zzp, if i did i would get the 3.8. On their site it says all ssm90 pulleys the same as a gtp pulley .3 smaller? or is that bs? Im just tryin to make sure here i dont want my KR to go though the roof. thanks
  2. #2 Re: hey is this pulley ok for my ssm90 setup?
    stock pulley is 3.8". with your mods, that's about all youre gonna get away with.
  3. #3 Re: hey is this pulley ok for my ssm90 setup?
    Ok thanks! Yea next upgrade will be headers, colder t-stat then I can maybe drop my pulley abit
  4. #4 Re: hey is this pulley ok for my ssm90 setup?
    many find you need headers just to run the top swap with the stock 3.8" pulley...
    leave the stock one on but get headers.
  5. #5 Re: hey is this pulley ok for my ssm90 setup?
    3.6 is about the best you can expect from a top swap with headers as your only mod.
    I'm running a 3.8 on a top swap with headers, ported TB and S/C.
  6. #6 Re: hey is this pulley ok for my ssm90 setup?
    Yea 3.6 is what I had in mind, where the gains noticeable compared to the 3.8? Also how's the ported TB? I've been wondering on if I should get one or not.
  7. #7 Re: hey is this pulley ok for my ssm90 setup?
    You attempt to smooth out the MAF hump in the TB.
    You'll need a street tune if you do it.
    Helps with throttle response.
  8. #8 Re: hey is this pulley ok for my ssm90 setup?
    Jersey
    with my mods, i can barely run the stock pulley
    16' wrx sti- stock
  9. #9 Re: hey is this pulley ok for my ssm90 setup?
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Quote Originally Posted by 99prixgt View Post
    What timing and 02's? OP 3.8 with stock mani's, 3.6 with plog DP setup and 3.5/3.6 with headers. intercooler or cam after that piont and larger injectors and pump rewire.
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  10. #10 Re: hey is this pulley ok for my ssm90 setup?
    Jersey
    Quote Originally Posted by 01gpgt01 View Post
    fat 02's 960's-970's sometimes even 980's
    15* wot timing
    2.5* of knock
    16' wrx sti- stock
  11. #11 Re: hey is this pulley ok for my ssm90 setup?
    Jan 1970
    Maquoketa, Iowa
    From the sounds of it, you are looking to just run a regular pulley on a ssm90 kit?
    The ssm90 kit uses special pulleys. You cannot use stock pulleys as you need the belt setup for that. You would need the balancer or crank pulley from a gtp and the idlers/ tensioners/brackets to run a supercharger belt.
    I would start off with a 3.8 pulley or higher and go from there.
  12. #12 Re: hey is this pulley ok for my ssm90 setup?
    ok yea il just run the stock 3.8 pulley, i have the belt setup for my m90, i have all the tensioners i need. thanks guys
  13. #13 Re: hey is this pulley ok for my ssm90 setup?
    15* wot timing
    2.5* of knock
    Get a wideband.
    980 is probably bad though...
  14. #14 Re: hey is this pulley ok for my ssm90 setup?
    Hagerstown,Md
    15* wot timing
    2.5* of knock
    My car would knock when 02's went over 960. You can knock from to much fuel.
  15. #15 Re: hey is this pulley ok for my ssm90 setup?
    Jersey
    Get a wideband.
    I have a wideband, afr is around low 11's
    if i try and take away fuel, it knocks more
    16' wrx sti- stock
  16. #16 Re: hey is this pulley ok for my ssm90 setup?
    Thats about where you'd want to be...
    Your engine must not like you lol.
    Have the heads ever been off?
  17. #17 Re: hey is this pulley ok for my ssm90 setup?
    Hagerstown,Md
    Wonder if you have an exhaust leak near the sensor tossing off the reading?
  18. #18 Re: hey is this pulley ok for my ssm90 setup?
    Jan 1970
    Maquoketa, Iowa
    No, narrowbands are just that ****ty anywhere else but light/no throttle.
  1. ssm90
    By nascartech in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-25-2010, 08:10 PM
  2. Pulley for my setup?
    By Amb4 in forum General Tech Discussion
    Last Post: 05-31-2010, 12:35 PM
