Thread: What gauges to get?
Results 1 to 20 of 26
  1. #1 What gauges to get?
    GT Level Member JCG's-GTP's Avatar
    Feb 2008
    Nashville
    I plan on getting the pillar gauge holder now the question is what gauges. I want a boost gauge and probably the areoforce scan gauge. What should I get for 3rd? suggestions?
    OverKill PCM, PRJ 10.4 Wires, AutoLite 605, WizAir CAI, ZZP Plog, 2.5" Down Pipe, 3.5 Pulley, 180* Tstat, Borla Exhaust MECA SQ JL AUDIO 500/1, 300/4, 2-10W3V2, XR650-CSI, Kenwood DDX-6019 , Alpine amp and JL TR400CX center channel , 300 lbs of Dynamat.
  2. #2 Re: What gauges to get?
    Banned
    Wichita Falls, Texas
    Oil PSI
  3. #3 Re: What gauges to get?
    Moore, Oklahoma
    Oil Pressure for sure.
    Shawn W. Larsen
  4. #4 Re: What gauges to get?
    Donating Users blowfishRus6's Avatar
    g.a.
    may i ask why oil pressure?? that needs to be keept a close eye on??
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  5. #5 Re: What gauges to get?
    Banned
    Quote Originally Posted by blowfishRus6 View Post
    Uhhhhh....yeah?
  6. #6 Re: What gauges to get?
    g.a.
    well i figured that but i was looking for more of a reason why?? i was looking to be educated...
    its slow.
  7. #7 Re: What gauges to get?
    Banned
    Drain the oil out of your motor, go drive it. You'll see why you would want to monitor this.
  8. #8 Re: What gauges to get?
    g.a.
    okay. but so your saying as long as you know there is oil in it then this aint all that important?? i was wondering if there was anything else that goes along with this?
    its slow.
  9. #9 Re: What gauges to get?
    g.a.
    but i see why that would be nice to know. just wondered if that went along with any other problems
    its slow.
  10. #10 Re: What gauges to get?
    Banned
    How do you know there is oil in the car while your driving it?
  11. #11 Re: What gauges to get?
    g.a.
    okay fine i get your point.
    its slow.
  12. #12 Re: What gauges to get?
    Feb 2008
    Nashville
    For some reason I thought our cars had oil gauges Then after you mentioned it I realized its just the oil life % lol. So is the scan gauge worth the money? And any suggestions on wich gauges to buy?
  13. #13 Re: What gauges to get?
    Barksdale AFB, LA
    Quote Originally Posted by JCG's-GTP View Post
    It also already monitors oil pressure, but apparently Pontiac didn't want to put it on your dash. I forgot that for a second too, since my car came with an oil pressure gauge.
    I think it's worth every penny.
    If you don't want oil pressure for some reason, I have fuel pressure and find it handy. Doesn't move a whole lot while driving, and rises when you stomp on it, but it is a definite warning to a failing pump if it decides to go while I'm being rough with it.
    2009 Subaru Impreza WRX STI
  14. #14 Re: What gauges to get?
    GT Level Member YoungGTP's Avatar
    Aug 2008
    Iowa
    just to add but, i put a 2 5/8 machanical boost gauge on the dash(with a cup and such) with room for a pillar gauge and im gonna run the areoforce, air fuel, and oil press. yes the areoforce has them but i wanna be able to always monitor them. any other suggestion instead of the air fuel?
    -98 GTP Thunderstorm
    Cai, 3.5 press on pulley, NGK TR6's, 3" to 2.5" exhaust, thrush glasspacks, drilled 180 t-stat soon-overkill pcm, fully ported sc, N* TB, and LQ4 MAF, Future- Full I/C, XP cam, s&s headers
  15. #15 Re: What gauges to get?
    Barksdale AFB, LA
    Aeroforce does not have air/fuel, and it also doesn't have oil pressure (oil pressure only works on some GM V8 engines like the LSx line). Air/fuel is useless on a narrow band O2 sensor. Just a pretty light show (if you want one I'll sell it to you on the cheap, as I never got around to installing it). Get something like oil temp, fuel pressure, etc that might actually be useful.
    Edit: To clarify the above statement, it has commanded air/fuel, not actual air/fuel measure from the exhaust. It does have O2 sensor readings in mV though.
  16. #16 Re: What gauges to get?
    Aug 2008
    Iowa
    whats the stock fuel pressure supposed to be with no rewire kit or injectors? and with a rewire kit for the pump?
  17. #17 Re: What gauges to get?
    Barksdale AFB, LA
    Quote Originally Posted by YoungGTP View Post
    Fuel pressure is supposed to sit between 50-60PSI with the engine running. Not sure what effect the rewire would have, but injectors won't affect it until your at WOT and the pump can't keep up anymore.
  18. #18 Re: What gauges to get?
    GT Level Member riceburner's Avatar
    Aug 2008
    denver, co
    just to answer the oil psi ? from earlier...the reason you want a oil psi gauge is to just be able to monitor the psi going thru the engine. if somethings happens such as the pump goes out of something gets cloged, then the gauge will relay that to you in the form of your psi dropping...think of it as an ses light for hidden problems...that answer the ?
  19. #19 Re: What gauges to get?
    Feb 2008
    Nashville
    I'm pretty sure he was j/king about that lol
  20. #20 Re: What gauges to get?
  1. Gauges
    By GP2003GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-15-2008, 05:54 AM
  2. What are the first Gauges to Buy
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-05-2008, 03:43 AM
  3. gauges
    By Chleby in forum Visual/Body Modifications
    Last Post: 02-12-2008, 03:51 PM
  4. gauges not working?
    By s1795so2 in forum General Tech Discussion
    Last Post: 01-13-2008, 12:11 AM
