Assuming you are a series 2 or 3 motor. If the electrical connector is still attached you turn the sensor counter clockwise with a a large adjustable wrench until you see the hole where you can access the clip holding the connector.
Once the electrical connector is off. Continue to spin the sensor counter clockwise until it's free. Slide it out and you are all set.
