Thread: how do you disconnect the oil level sensor from the oil pan.
Results 1 to 2 of 2
  1. #1 how do you disconnect the oil level sensor from the oil pan.
    missouri
    I have all the bolts out of my oil pan, but i cant seem to get the sensor out, cant afford to destroy it. Please help. Thank you -98regalgsx.
  2. #2 Re: how do you disconnect the oil level sensor from the oil pan.
    Assuming you are a series 2 or 3 motor. If the electrical connector is still attached you turn the sensor counter clockwise with a a large adjustable wrench until you see the hole where you can access the clip holding the connector.
    Once the electrical connector is off. Continue to spin the sensor counter clockwise until it's free. Slide it out and you are all set.
  1. Low Oil Level Light Still Comes On After Low Oil Level Sensor Replacement
    By LoveMyGPGT in forum General Tech Discussion
    Last Post: 04-23-2017, 09:20 AM
  2. What happens if you disconnect the Magna Steer?
    By Blown97 in forum Brakes/Suspension/Chassis
    Last Post: 12-27-2012, 08:50 PM
  3. coolant level sensor, you gotta be crapping me!
    By Teardrop in forum The Rant Forum
    Last Post: 09-12-2010, 09:17 PM
  4. Disconnect FM antenna to make mp3 player work better?
    By RobotBastard in forum Audio, Security & Visual Electronics
    Last Post: 09-10-2009, 01:32 AM
  5. HELP! FP leak at large quick disconnect!?!
    By alacran in forum General Tech Discussion
    Last Post: 07-24-2008, 01:01 PM
