Thread: FIXED!! Engine studder, tach drop, P1361 (video added)
Results 1 to 20 of 23
  1. #1 FIXED!! Engine studder, tach drop, P1361 (video added)
    Feb 2008
    I've been having a few issues with my '97 GTP. Last winter it happened a few times, and now that it's cooling off again, the problems is coming back and it's getting a bit worse. Sometimes, especially under heavier loads, I'll get what feels like fuel cut. Also, during extended periods episodes of the hiccups, my DIC will flash 0.0 constantly until I shut the car off. At idle, if it hiccups, I notice the tach drop to zero momentarily.
    Last winter, it popped a code a few times related to the ignition control module not getting a proper signal from either the cam or crank sensor (I can't remember exactly). As of now, though, there are no codes stored, but it keeps acting up.
    Anyone have any ideas what may be my problem?
    Here's the vid:
  2. #2 Re: Engine studder, tach drop, no codes
    Charles City, IA
    tach dropping to zero is normally a bad crank sensor.
    SMGPFC Two Nipple General
  3. #3 Re: Engine studder, tach drop, no codes
    Feb 2008
    That's what I'm hoping is the only problem. Why would it seem to act up only when it's colder outside, though?
  4. #4 Re: Engine studder, tach drop, no codes
    Feb 2008
    Just scanned it again. Got a code this time. P1361 Definitely related to the CKP sensor... Might just be time to replace it. It is the original with almost 140k miles of abuse.
  5. #5 Re: Engine studder, tach drop, P1361
    Charles City, IA
    Yup they are easy to do.
  6. #6 Re: Engine studder, tach drop, P1361
    Feb 2008
    Looked up more code specifics and found nothing about the CKP sensor. It all points to the ICM, PCM, or wiring. Possible loose wire at the computer or bad ground?
  7. #7 Re: Engine studder, tach drop, P1361
    Grocery Getter x2 goldgp's Avatar
    redneck tennessee
    I know that when my crank pos sensor went out, it only acted up when hot.I pored bottled behind the balancer onto the sensor and actually got it cooled enough 2 get it working once,lol.But when mine acted up the trac off light would also come on.
  8. #8 Re: Engine studder, tach drop, P1361
    For the cost and consistency, I'd go after the crank sensor first. It's the most common issue.
  9. #9 Re: Engine studder, tach drop, P1361
    Feb 2008
    I'll pick one up and install it. I'll update when I get it put on.
  10. #10 Re: Engine studder, tach drop, P1361
    Feb 2008
    Picked up a new ckp sensor last night and will hopefully get it on today after work.
    One thing I noticed last night when it did its thing and the tach dropped, the speedo also started to drop rapidly, but didn't make it to zero before everything picked back up. Then, when I started to accelerate after that, the speed display on the HUD acted like I had lost traction and spun the tires up over 100, then resumed to normal (I was barely touching the throttle).
  11. #11 Re: Engine studder, tach drop, P1361
    Feb 2008
    Okay, so the CKP sensor didn't help any. I did take the PCM apart and inspect it to make sure there were no bad solder joints and they all looked good to me. After re-installing it, I caught one hiccup and haven't had any other major issues since then. I can only assume that the problem was/is in the PCM plug or the first foot of wiring to it.
    What do you guys think?
  12. #12 Re: Engine studder, tach drop, P1361
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    Where is the crank sensor located and hoe do you install it? I wanna change mines for preventative maintenance.
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  13. #13 Re: Engine studder, tach drop, P1361
    Feb 2008
    It's in the how to section of the forum...
    http://www.grandprixforums.net/cps.php
  14. #14 Re: Engine studder, tach drop, P1361
    Bowie, MD
    Thanks dan
  15. #15 Re: Engine studder, tach drop, P1361 (video added)
    Feb 2008
    I got a video on the way home. It's real low quality, but you can still see what's going on sometimes. The HUD speedometer goes crazy while the analog one works just fine. The DIC also just flashes 0.0.
  16. #16 Re: Engine studder, tach drop, P1361 (video added)
    SE Level Member djs4021's Avatar
    Youngstown, Oho
    my 01 is doing something really similar. dont mean to thread jack but mine only does it from a stop at about 50% throttle. it jerks hard and the speedo on the hud goes wacky. i dont get the 0.0 on the DIC tho. i had it at the dealer to diagnose my EBCM as bad before my car started doing this and they told me my computer might be bad. i guess all i'm asking for is a little direction. fuel filter is about 12000 miles and tune up has about 5000. definitely fuel cutting issue tho. please help
    01 Grand Prix GTP 8.8 MSD wires, K&N FIPK, ZZP Ceramic coated PLOG, ZZP 3'' Off-Road DP, Res Del, Borla Pro XS mufflers, Progress front sway, GMPP rear sway
    02 Bonneville SE with ZZP SSM90 kit. R.I.P
  17. #17 Re: Engine studder, tach drop, P1361 (video added)
    Feb 2008
    Mine is not cutting fuel to my knowledge. It seems to not be firing the coils.
  18. #18 Re: Engine studder, tach drop, P1361 (video added)
    Feb 2008
    I FIXED IT!!!! I think...
    I tore apart the wiring harness between the ICM and cam/crank sensors and separated the ground wire out. There was a burned spot on it where it was folded up in the harness. I taped it up, reintegrated it back into the harness without the fold, and hooked everything back up. I also found a plug wire that wasn't staying connected to the #5 tower. I modified the connector and popped it back on. One or both of those two things fixed it. I've been driving it a lot for the last 3 days with no issues at all!
  19. #19 Re: FIXED!! Engine studder, tach drop, P1361 (video added)
    I live here. TLSheff's Avatar
    NICE!
    lets hope that did the job
  20. #20 Re: FIXED!! Engine studder, tach drop, P1361 (video added)
    Feb 2008
    Been beatin' on it all day today with no hiccups or anything. Now I can finally look forward to upgrading the fuel pump!
  1. Engine codes
    By postalizer in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-10-2010, 10:20 AM
  2. Help with SES codes, engine surging.
    By Fast68Camaro in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-23-2010, 06:20 AM
  3. SS intercooler and header install = engine codes
    By rascal in forum General Tech Discussion
    Last Post: 09-01-2009, 08:41 PM
  4. 97 GTP engine codes
    By willy4x4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-03-2009, 12:31 PM
  5. engine light/trouble codes
    By Jakegday in forum General Tech Discussion
    Last Post: 01-02-2009, 08:03 PM
