Thread: start my car and it goes to the rev limiter
Results 1 to 12 of 12
  1. #1 start my car and it goes to the rev limiter
    guys i cant figure this out... I start my car and it goes to the rev limiter instantly.
    I have no vac leaks and replaced the TPS and nothing has worked...this is my DD so i need some help in a solution please
    -Jarred
  2. #2 Re: start my car and it goes to the rev limiter
    Outer Space
    unhook the throttle cable off the tb and crank it.
    02 GTP 13.6 @ 100mph - SOLD
  3. #3 Re: start my car and it goes to the rev limiter
    Actually I'd say check the throttle to see if it's being held open. If so unhook the cruise control cable (if it's messing up it couldl hold ya open) and then check the throttle cable for binding.
  4. #4 Re: start my car and it goes to the rev limiter
    the throttle plate is shut like normal... its not open or anything
  5. #5 Re: start my car and it goes to the rev limiter
    it started while i was driving and was pegged at 2500 rpm and in park it hits the rev limiter
  6. #6 Re: start my car and it goes to the rev limiter
    There's 2-3 things that can control rpm.
    Throttle position sensor (which if it was maxed the pcm should see it and toss a code)
    IAC, could be stuck open..that can do it. I'd pull it and clean it.
    Throttle plate..you've confirmed that, so rule it out.
    MAF shouldn't because even if it lied to the pcm about airflow ...you'd choke out the cylinders w/o having enough air for the fuel.
    Major vaccum leak.
  7. #7 Re: start my car and it goes to the rev limiter
    where is the IAC? sorry im running a N* i should have mentioned that...
  8. #8 Re: start my car and it goes to the rev limiter
    before I changed the TPS i threw the P1122 and P0122 codes
  9. #9 Re: start my car and it goes to the rev limiter
    Portland Oregon
    Those are both tps codes. If you've replaced the tps, it's time to trace wires
  10. #10 Re: start my car and it goes to the rev limiter
    Feb 2008
    Since you're running a N*, make sure the TPS adapter is plugged in securely. I had a similar problem a while back with my N*. The connection at the factory plug to the adapter didn't seem to be secure. I unplugged it, added a touch of dielectric, and plugged it back in. No problems since then.
  11. #11 Re: start my car and it goes to the rev limiter
    Quote Originally Posted by DanGTP View Post
    That did it!!! Thanks Dan!!
  12. #12 Re: start my car and it goes to the rev limiter
    Feb 2008
    Glad I could be of assistance. I just know how temperamental those plug adapters are...
    I'll be attempting to re-pin the factory plug to the N* tps plug in the future, to avoid the problem in the future.
  1. ECU speed limiter possible?
    By PCweber in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-19-2010, 09:52 PM
  2. Limiter question..
    By Ninjo in forum General Tech Discussion
    Last Post: 11-03-2008, 11:24 PM
  3. Speed limiter?
    By Randy_W in forum General Tech Discussion
    Last Post: 05-23-2008, 09:58 AM
  4. Speed limiter @110 WTF???
    By ABINOK in forum General Tech Discussion
    Last Post: 03-20-2008, 08:55 PM
  5. Speed Limiter
    By oh_grand_prix in forum PCM Tuning
    Last Post: 01-30-2008, 11:56 AM
