Thread: sounds like marbles
Results 1 to 14 of 14
  1. #1 sounds like marbles
    SE Level Member Ryansgtp's Avatar
    Jul 2010
    Medina NY
    Once in a while when I'm just going normal speed, just on normal throttle I will hear a weird sound kind of like marbles bouncing around in a pan, coming from the front of the car and you can kind of feel it through the peddle. If you let off of the gas and go back on it it goes away. Anyone know what this could be? It doesn't affect performance while its doing it but I just don't want it to cause damage down the road.
    Just starting out on my 2001GTP.
    Intake, tints, audio, interior. More to come in the future
  2. #2 Re: sounds like marbles
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    Blip the throttle from under the hood. It could be the blower snout coupler. Cheap and easy fix if it is.
  3. #3 Re: sounds like marbles
    Jul 2010
    Medina NY
    do you mean to rev it from under the hood and will I be able to tell something is wrong?
  4. #4 Re: sounds like marbles
    Topeka, KS
    That's what hes getting at. You will hear the Supercharger Coupler rattle. Also in the colder months our cars are quite noisy with the custom intakes due to the motor warming up and it sounds like marbles in a can sometimes.
  5. #5 Re: sounds like marbles
    The noise isn't from the intake Rebecca...its from the IAC.
    As for marbles...check out my facebook videos I've been tagged in...there are two start up videos of my car...the 2nd one is with a bad set of rotors and S/C coupler. You can hear it clear as day since I have my catback on. Annnnd...its nasty. Good way to rule out anything blower related is to just take off the supercharger belt and start it up...yes its safe...just dont beat the crap outta it.
  6. #6 Re: sounds like marbles
    Las Cruces, NM
    Good point, take off the blower belt and drive the car, just don't go full throttle.
  7. #7 Re: sounds like marbles
    Topeka, KS
    But.... the aftermarket intake lets you hear it more than the stock airbox ever did. Nancy...
  8. #8 Re: sounds like marbles
    Nov 2008
    Waterloo, Iowa
    But with the supercharger, you'd more likely hear it when idling in drive then when on the throttle... at least that's how it is for me.
  9. #9 Re: sounds like marbles
    Colorado Springs, CO
    thats the way mine is right now.. mostly only hear it at idle with it in gear. almost reminds me of a power steering pump going out. thats what it sounds similar to anyways. just ordered the new coupler and the kit and new oil for 60 bucks off of zz perfomance
  10. #10 Re: sounds like marbles
    Topeka, KS
    You can get the oil from any GM Dealership / Parts Dept. Probably cheaper too.
  11. #11 Re: sounds like marbles
    Nov 2008
    Waterloo, Iowa
    Quote Originally Posted by rynoman03 View Post
    ZZP Oil is cheap, cheaper than most parts dealers around here.
  12. #12 Re: sounds like marbles
    Jul 2010
    Medina NY
    Ya the noise isn't from the intake or Iac I know what that sounds like. It only happens once like every othe drive. So if I take the belt off it will stop or do it all the time?
  13. #13 Re: sounds like marbles
    Yea zzp oil is much cheaper. I paid 10 for a 6 ounce bottle that will fill my charger compared to 7.99 for a 4 ounce bottle of gm
  14. #14 Re: sounds like marbles
    ZZP is just a bunch of crap.
    Quit feeding their mouths over there with junk oil talk. GM Oil only...I used ZZP oil and it went bad FAST. Just take the belt off...its fine for the car. If you take the belt off and the noise stops...then you know its supercharger related...the end.
  1. GT sounds like a gtp?
    By betsgtp in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-01-2010, 09:20 PM
  2. Exhaust Sounds
    By MBruneaux in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-18-2010, 12:20 AM
  3. tell me how good this sounds....
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 03-01-2010, 01:09 PM
  4. whirring sounds in 4th
    By flash527 in forum General Tech Discussion
    Last Post: 10-05-2009, 12:29 AM
  5. Cai Sounds Like Crap!!!!
    By Gearhed42 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-05-2008, 08:58 AM
