Thread: weird results from zzp logs
Results 1 to 20 of 25
Threaded View
  1. #15 Re: weird results from zzp logs
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Quote Originally Posted by gtpsleeper View Post
    stock injectors and no rewire... i wouldn think fuel rails would cause that much of a KR increase though?
    Your injectors are undersized. Your pumps probobly falling off. Scan would confirm this. Fuel logs would not effect coolant temps. Sounds like you have a Wide open Thremostat. Lower Coolant temps would also increase spark timing WOT by a few degrees if your running the stock Add table. This could be where your getting knock. Also I think 145 degrees Coolant temp is where the car goes from open loop to closed loop fueling. If its in open loop its not reading off the oxygen sensors. If the gauge is pegged at 160 and not moving its hard to tell what your ECT is reading
    So you need to replace the thermostat or the Coolant temp sensor. Post a scan when you get to normal operating temps so we can see where your Injectors and pumps siting at
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  1. sexy results :)
    Last Post: 05-12-2010, 08:48 PM
  2. my friends track results
    By BoostJunki3 in forum Track Sessions and Kills
    Last Post: 04-16-2010, 11:59 PM
  3. Sme track results and VIDEOS
    By GINOSGTP in forum Off Topic Discussion
    Last Post: 08-28-2009, 06:20 AM
  4. results on the 07 ss
    By joe deleon in forum Track Sessions and Kills
    Last Post: 05-10-2009, 01:06 PM
  5. OFFICIAL BGPM 2008 Results
    By webracin in forum Shows and Events
    Last Post: 09-26-2008, 04:06 PM
