Thread: check engine light only when under a quarter tank of gas
Results 1 to 18 of 18
  1. #1 check engine light only when under a quarter tank of gas
    Saskatchewan, Canada
    I have an 02 GTP. My check engine light flashes a couple seconds then goes out, only when accelerating hard to pass someone on the highway. But it only happens if theres under a quarter tank. It runs fine all the time even when the light flashes. The light stayed on once (solid, no flash) but i disconnected the battery and its out.
    I am taking the car in but I would greatly appreciate anyones input before I go to the mechanic.
  2. #2 Re: check engine light only when under a quarter tank of gas
    Pennsylvania
    Injectors, injector plugs on wire harness, fuel filter, fuel pump...
  3. #3 Re: check engine light only when under a quarter tank of gas
    Jul 2008
    sumter,south carolina
    yea ur definitely misfiring.
    02 GTP with mods 05 GP for DD
  4. #4 Re: check engine light only when under a quarter tank of gas
    Apr 2009
    stockton ca
    thats bad fix it now
  5. #5 Re: check engine light only when under a quarter tank of gas
    Thanks for the replies guys.
    The check engine light won't come on anymore, I let the gas get right down to where it usually is when the light will come on, I floored it on the highway a bunch of times and it won't do it anymore.
    I don't know if i mentioned i just bought it a couple months ago. Anyway, I noticed yesterday there was oil leaking, I got under it and the oil filter was really loose (I turned it at least five times to tighten it!). I also put 94 octane instead of the 91 octane they have at most places. I don't know if either of these things helped the engine light from flashing (under 1/4 tank with full throttle only on highway) but it won't come on anymore.
    I am still going to put new plugs and maybe wires too, also maybe a fuel filter. Any other suggestions would be appreciated. The car has 90000miles and I'm not sure whats all been done besides new tires,brakes,intake man. gasket.
  6. #6 Re: check engine light only when under a quarter tank of gas
    Jan 2009
    Tallahassee, FL
    You HAVE to run premium on these cars, that was likely the problem if it stopped when you filled up with 94. Go ahead and do a full tuneup with a half of can of seafoam through the gas and the other half through the motor.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  7. #7 Re: check engine light only when under a quarter tank of gas
    Jul 2008
    yea u can do internal damage to these motors running less than 93.
  8. #8 Re: check engine light only when under a quarter tank of gas
    Premium gas is only 91 octane everywhere except one place in Prince Albert SK.(Can.). It also says in the owners manual to run 91 octane. Anyway I'm glad I found the one place. I had the fuel filter changed, plugs and wires. Everythings good, except a tiny leak in the front valve cover gasket, nothing big. Thanks again!
  9. #9 Re: check engine light only when under a quarter tank of gas
    Jul 2008
    that tiny leak will get bigger.... possibly cause an engine fire.. there is a recall out on it. get it done for free. glad u got it running right
  10. #10 Re: check engine light only when under a quarter tank of gas
    Grand Rapids, MI
    i got (the same?) recall done on mine it was a fire safety thing and all they did was put plug wire retainers in. there was no valve cover gasket recall...if that's what you were referring to.
  11. #11 Re: check engine light only when under a quarter tank of gas
    Jul 2008
    been a few years... but im pretty sure they did the gasket on mine.
  12. #12 Re: check engine light only when under a quarter tank of gas
    Jan 2009
    Tallahassee, FL
    The recall is for the valve cover
    77 Morris Garage B
  13. #13 Re: check engine light only when under a quarter tank of gas
    Grand Rapids, MI
    well my valve cover must have already been done...
    i know they just put some spark plug retainers in for the fire hazard.
  14. #14 Re: check engine light only when under a quarter tank of gas
    Cool, didn't know about the recall. Is it for both valve covers. The back is a little damp but the front is worse. Either way its going in next Tuesday. Thanks for the tip guys!
  15. #15 Re: check engine light only when under a quarter tank of gas
    Sorry guys, one more stupid question. There is a little bit of oil on the top side of the valve cover gathered in a spot by the intake manifold gasket. I think it is from the valve cover but could it be from somewhere else? Stupid question-does oil go thru intake manifold at all? I don't know alot but I'm trying to learn. It is absolutly oil, not coolant. The valve cover is an inch above it so I hope thats where its coming from.
    Thanks again.
  16. #16 Re: check engine light only when under a quarter tank of gas
    N/A = plug retainers
    S/C = VC gasket and possibly the plug retainers as well.
  17. #17 Re: check engine light only when under a quarter tank of gas
    thanks matt.
  18. #18 Re: check engine light only when under a quarter tank of gas
    Thats for the recall.
    Oil isnt supposed to run in the UIM/on top of the LIM but it does because of the PCV system.
  1. Check engine light on
    By CMURDAx in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-06-2010, 10:11 PM
  2. Check Engine Light
    By Alpha388th in forum General Tech Discussion
    Last Post: 02-20-2009, 11:48 PM
  3. check engine light
    By kiljoy06 in forum General Tech Discussion
    Last Post: 01-11-2009, 07:27 AM
  4. Check Engine Light
    By WHITE02GTP in forum General Tech Discussion
    Last Post: 10-08-2008, 10:31 PM
  5. Check Engine Light
    Last Post: 09-01-2008, 09:01 PM
