Thread: Fuel Pump/Resistor issue
Results 1 to 8 of 8
  1. #1 Fuel Pump/Resistor issue
    WI
    I have a 1997 Grand Prix GTP. It starts without an issue, but dies after 4-5 seconds. After research I noticed that it usually is the fuel pump resistor. Well, I went ahead and did the bypass and it ran good when I did that.Aside from the raw gas I could smell from the exhaust. Well, I go the boneyard and pulled litterally 15 of them. Well, EVERY single one I put on... it would die again. I'm kind of stuck. Don't really wanna spend the money on a new one if that not exactly it, because I highly doubt EVERY single one of those were bad. I'm leaning torwards the pump is bad and will only run right on high. I hear it kick on regardless of what resistor is in there. I also switched the fuel pump relay and the fuel pump speed resistor with no success(I seen they were the same part #). Any ideas would GREATLY be appreciated.
  2. #2 Re: Fuel Pump/Resistor issue
    Willoughby, Ohio
    is it throwing any codes? if yes, it could be the MAF sensor, if not it could be the CPS
    i say this because you can hear the puimp priming correct?
    so i sense no problem there
    however you say you smell gas, from only the exhaust or the engine bay too? or from under the car in general
  3. #3 Re: Fuel Pump/Resistor issue
    WI
    No codes are being tripped at all; and yes the fuel pump is primming the system. And I can only smell the gas comming from the exhaust when the bypass is done to the fuel pump speed resistor, which makes it run on high.. But doing that makes the car run without dying. As soon as the the bypass is reversed to normal.. back to dying. But I've tried replacing that resistor without any luck.
  4. #4 Re: Fuel Pump/Resistor issue
    WI
    Also the pump is kind of noisy, but has been since I've had the car. Makes a whinning noise. I've also had cars in the past do that too without an issue.
    1997 GTP 102k - Near stock with loads of new parts
  5. #5 Re: Fuel Pump/Resistor issue
    Willoughby, Ohio
    maybe the fuel pressure regulator is going bad if the pump cant operate on low
  6. #6 Re: Fuel Pump/Resistor issue
    WI
    Well.. I replaced the regulator. No luck. I then went ahead replaced the fuel pump thinking the coil went bad... No luck. I put a pressure test on it and it is DEFINETLY loosing pressure. When I run the bypass on the relay though it stays running with the proper fuel pressure. I'm really stuck here.
  7. #7 Re: Fuel Pump/Resistor issue
    WI
    Also, I see you have cold air intake on yours.. what did you do with the computer?
  8. #8 Re: Fuel Pump/Resistor issue
    Willoughby, Ohio
    left it set in there where the airbox used to be
  1. Fuel Pump Resistor By Pass Mod
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-02-2012, 05:49 AM
  2. Thanks for fuel pump resistor, but with only first gear?
    By BoilerGoldGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-06-2010, 08:55 PM
  3. Fuel Pump Resistor Question
    By guitarguyucf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-26-2009, 04:49 AM
  4. Do any of the N/A 3800's have a fuel pump resistor?
    By ssnapier in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-10-2009, 06:34 PM
  5. fuel pump resistor
    By gnjim in forum General Tech Discussion
    Last Post: 03-02-2009, 08:26 AM
