Thread: Car sputters when accelerating hard
Results 1 to 17 of 17
  1. #1 Re: Car sputters when accelerating hard
    Donating Users Tengis's Avatar
    Houston
    few inches to get at the back ones.
    I have long arms + massive forearms and I can get to all plugs easily in modified or stock engine bays without moving anything.
    Whenever I have had this issue with a car I will spend 25-30 minutes and check the spark plugs for cracks, check the wires and/or swap out a set with a known good set to see if thats the problem before buying a set for that car, swap out the ignition coils with known good ones from another car, swap out the ignition control module with known good one from another car.
    Silver R32 Skyline GTS-T
    Satin Purple 97 GTP
    Blue 01 IS4 + M112 hybrid GTP
    Satin Black 98 Turbo GTP
    ZZP recommended installer - Kratos Concepts
  2. #2 Re: Car sputters when accelerating hard
    SE Level Member joemama22's Avatar
    Well it turns out it was the CAT. After changing it, it runs better than when I bought the car. The whole inside of the CAT was broken in pieces.
    Now I just have to figure out whats causing the Service ABS, Service Brakes, Service Stability Control, Service Traction Control, and Service Variable Effortless Stearing lights to go on. The car runs perfect, so Im not sure why these lights are all coming on. Let me know if anyone else has this problem.
  1. bad vibration while accelerating help please!!!
    By 01RedfireGT in forum Brakes/Suspension/Chassis
    Last Post: 09-29-2012, 08:54 PM
  2. 2001 Grand Prix GTP Sputters when cold.
    By jeepers in forum Engine
    Last Post: 10-06-2011, 09:30 AM
  3. Sputters on start, sometimes
    By busagtp in forum General Tech Discussion
    Last Post: 05-20-2010, 07:22 AM
  4. 1998 Gd Prix sputters and stalls when engine warm
    By jmickevi in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-18-2010, 02:05 AM
  5. 02 GP Shakes upon accelerating
    By riddell87 in forum General Tech Discussion
    Last Post: 01-08-2010, 11:11 PM
