Thread: Electrical wigging out
Results 1 to 3 of 3
  1. #1 Electrical wigging out
    tacoma
    97 GTP- DIC,HUD, flickering off and on headlights get brighter and no power in first gear, with wierd whinning noise. issue comes and goes. Already replaced bat and alt, cleaned terminals and grounds added an extra ground to ECU.
    This thing is driving me nuts and has my mechanic stumped, can anyone help?
  2. #2 Re: Electrical wigging out
    Mesa, AZ
    ignition switch for your electrical problems...worn tranny for the power...your car is supercharged hence the whine...these cars are like hormonal women you knever know what is going to piss them off.
  3. #3 Re: Electrical wigging out
    GT Level Member mikedinthecity's Avatar
    Apr 2009
    Southfield, Michigan
    there has to be sumthing shorted to ground which is making the alt whine b cause of the load. look by the starter, there are a bunch of pos wires there make sure none of them r touching engine or are grounded. also check the pos cable by the battery and the pos wire foir the alt, follow them look for a short to ground. also still could be alt.....good luck with the problem to get fixed.
    2000 Daytona 500 GTP. fender well intake K&N, 180 tstat, flipped dog bones, strut2strut brace, sd headers coated n wrapped, 3in dp, 3.25 pulley, pcm tune, led tails, angel eye halos w 100 watt h1s, p&p heads, p&p m90, yella terra alum roller rockers, head studs, 8mm wires, al104s, 2007 l26, 329s hd diff, alum sub frame
  1. Need some electrical help
    By Green97GTP in forum General Tech Discussion
    Last Post: 08-17-2010, 07:28 PM
  2. Electrical!!!! HELP
    By gtpman in forum General Tech Discussion
    Last Post: 11-08-2009, 06:42 PM
  3. Electrical
    By Brandan2670 in forum General Tech Discussion
    Last Post: 03-30-2009, 01:52 PM
  4. Electrical
    By 97gp97 in forum General Tech Discussion
    Last Post: 11-10-2008, 04:02 PM
  5. Electrical (HELP)
    By tooez in forum General Tech Discussion
    Last Post: 05-24-2008, 07:28 PM
